Question about Frigidaire Refrigerators
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
THE SMALL EXPOSED AREA BETWEEN THE FREEZER DOOR AND FRIDGE DOOR IS GETTING VERY VERY HOT--WHAT IS THE PROBLEM
  • 218 Answers
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Posted on Nov 05, 2008
    Scholar:
  • 62 Answers
There most likely isn't a problem. As long as it is cooling ok most units either have a heater behind that panel or thay run one of the lines from the compressor through there to keep it from sweating. If it is extremely hot (cant hold your hand there for more than a few seconds) I would check to make sure the coils are clean and if applicable make sure your cooling fan or fans by the compreesor a running. Usually if there is a problem with the coils etc. the unit wont be cooling as good as normal. All that to say it is usually normal for that panel to be hot. If you have just gone to the store or if it hot in your location that panel may be hotter than normal. Hot enough that you dont want to keep your hand there long. Check coils, fans,etc. if that checks out it should be just fine.
    President:
  • Frigidaire Master
  • 2,651 Answers
Problem is the refrig is running to hot needds a cool air flow to the compressor/condensor area, youll need to vaccumm the underneath of unit for starters, andthen check the compressor area behind refrig for a fan that is supposed to be cooling off compressor.
Water under crispers and ice on freezer floor
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 09, 2015 | Refrigerators
I have a Samsung french door fridge.
Apr 02, 2015 | Samsung RFG297AAWP Side by Side Bottom...
Refrigerator freezer water leaks
Mar 31, 2015 | Kenmore Refrigerators
My whirlpool CB239W fridge is not draining condensed water away
Feb 22, 2015 | Whirlpool Refrigerators
Rf267 freezer leaks water
Jul 28, 2014 | Samsung Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Jul 15, 2014 | Samsung Refrigerators
Why is water leaking out of the freezer
Jul 04, 2014 | Kenmore Refrigerators
Water on the floor, coming from freezer area (there's ice on the freezer floor). Is there a drain hole or plug somewhere?
Jun 27, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Why is water and ice forming on bottom of my refrigerator?
Jun 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
Freezing around door of freezer
Jun 01, 2014 | Samsung Refrigerators
Refrigerators Logo
269 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
