Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2004 Wide Glide electrical issue's
Alright I will jist get started, the battery is new and has good charge. I replaced the stock handle bars with 18'' hangers. I start it and head down the road, I go about 1/4 mile and it dies, loses all electrical power. times vary (from 5 min to days) but I wait, turn the ignition back on ad it starts back up. I have started it and wiggled wires but I cant find anything and cant reproduce the problem. the only thing that I can think is it is due to high humidity, and water getting somewhere that it shouldnt be, but that doesnt explain the 5 minute wait. Any Ideas????
  • xdirtmonkeyx Nov 11, 2008
    I have a custom 02 Fatboy, it started shutting down while riding on the highway of all places. I checked the battery and replaced with a gel battery and the problem continued. I determined the stator was fine as the battery wasnt dead it was just not maintaining a charge. I then replaced the voltage regulator and it happened again.......it shut down after riding approx 100 miles.............after spending over a couple hundred dollars Im back to square one.........
    Patrick in Arizona
  • 216 Answers
You might have a bad sensor, The bank angle sensor turns off the ignition system when it THINKS the bike is leaning over 55 degrees. . The sensor is located behind the electrical panel and can be checked with a magnet. Electrical probelms can be a *****. Start by checking your charging system. Put a voltmeter on your battery. It should read about 12.5. Turn the engine on and the reading should increase to about 13.5. If it decreases, its the regulator or stator.
I had a bad crank position sensor on my wideglide that took me hours to run down. Good luck. Let me know what you find
Posted on Nov 05, 2008
2004 Harley Davidson FXDWG - FXDWGI Dyna Wide Glide dies with the slightest amount of throttle
Hi, Ike and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump or internal fuel line has pinholes.
17. Fuel injectors clogged or faulty.
18. Faulty throttle position sensor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
1993 Dyna Wide Glide
Harley Davidson Dyna Glide Twin Cam 88 Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally
Dec 18, 2017 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Replace handle bars on 2012 harley davidson dyna wide glide
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
How to Install Handlebars on 2012 Harley Street Glide
Feb 19, 2013 | 2008 Harley Davidson FLTR Road Glide
How to change handle bars 2011 wide glide
Mar 07, 2012 | 2011 Harley Davidson FXDWG Dyna Wide Glide
How many fuses are on a 2004 dyna wide glide?
Hi Robert, try this first, turn the ignition key to on then remove the maxi fuse or disconnect the main circuit breaker and leave the switch on, then replace your battery and maxi fuse/main breaker, for more information about your question please visit the websites below. On a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Feb 01, 2012 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
My 2004 Harley davidson dyna glide will not start or turn over
1. make sure the battery has a good charge
2.check all connections between the battery and the starter inc. coil solenoid and starter button
Mar 25, 2011 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Battery good, regulator good, stator good, battery won't charge
you have caused a wireing fult thats all, it likely to be a bad earth on the bars or you may have blown a fuse by shorting some thing out when you were doing the work start checking the wireing out with a meeter start from the regulator you should have volts from there back to the battery check for a main fuse as well
Jan 21, 2010 | 2002 Harley Davidson FXD Dyna Super Glide
Rewireing 93 harley davidson FXLR to 96 Handle bar
On the handlebar switches, Harley hasn't changed the color code scheme very much over the years but you really need a good schematic to know exactly how they are wired up. If you can find either a Harley service manual for a 96 model or a Clymer's manual, it would be helpful. I have a schmatic for a 94 FXDWG that should be alright for your 93 FXR but you need a schmatic for a 96 model bike.
Oct 07, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Motorcycle wont start
Check your spark plugs, they are quite fragile & yoy may have a crack in the ceramics. Replacement is recommended.
Apr 24, 2009 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Any good suggestions for Super Glide Sport bars?
I put pullback Deuce bars, 56330-00, along with pullback risers on my Wide Glide and like the fit. Total pullback is about 11.5". You can also get chrome FXST bars this year, 56154-04, which are close to the Deuce bars. I also put in urethane bushings which do add a little vibration, not bad but I can feel the difference. Deuce: 31" wide, 5" rise, 9" pullback. FXST: 30" wide, 5.75" rise, 9.25" pullback. Reply With Quote
Nov 20, 2008 | 2003 Harley Davidson FXDX Dyna Super Glide...
Lands Phones Logo
267 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
