Question about Samsung ML 1750 Laser Printer
Sumsung 1750 printer will not print
Samsung 1750 will not print. I have switched USB cable, disconnected all the plug-ins and re-connected, etc. HELP!
    Sergeant:
    Novelist:
  • 196 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
thanks.
Posted on Nov 05, 2008
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
The compuer is not connected
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
An error occured while printing
  4. Reboot computer.
Jan 12, 2012 | Lexmark X6675 All-In-One InkJet Printer
Lexmark X4550 Scanner not working
  4. Reboot computer.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Can not reinstall printer
Try disconnecting the printer from the USB port and reinstalling the CD program. Don't connect the printer to the USB port till the program says to do so.
Hope this help. Bud
Jan 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
Samsung ML 1750 Laser Printer Logo
115 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
