Question about Alpine CDA-7892 CD Player
How to instal my deck to a amp and sub
Please include?
  • Anonymous Nov 11, 2007
    Hola
    para instalar el eclipse 5303R como son las instaaciones conelprocessor 2301 no esta claro eso
  • Anonymous Apr 07, 2009
    hi everyone..i have 2 amps.1 for the front 2 speakers and anuva amp in the back for the two rear and the sub???i dont no why as u onli need 1 amp. they have put to much power through and has blown all speakers.. so iv taken out the front apm wts wired to the front speakers.now my cd player does not work??????????why is this?and also how do make my cd player work again and how do i wire my sub and amp???thankyou
How the heck do you turn on the sub option for this head unit..i lost the manual and no manual seems to be downloadable anywhere on the internet.
Posted on May 15, 2008
    Problem Solver:
  • 18 Answers
You would need rca cables, power wire, ground wire, and remote wire. it is easiest to just go to your local best buy or circuit city stores and buy the whole set in one package. rca's lead from your decks rca output jacks to your amp, remote wire leads from your decks wiring (blue remote wire that leads to your deck itself to give it remote) or any 12 volt source like where your fuses are located and it runs to the amp also, your power wire will lead from your battery to your amp, and your ground will need a good place somewhere in your car and be bolted or screwed to the frame of your car. this is how to intall your deck to your amp. i assume that you already know that wires will have to be under your carpet or kickboards and such however you run them. i think this covers the basics and i hope i have answered your question right, good luck
Posted on Oct 06, 2006
2 Suggested Answers
JustJeeps
  • 74 Answers
SOURCE: sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Posted on Nov 21, 2008
Sub problem with kenwood deck
well sounds like you crossed a wire somewhere. I would go through all the wires and check all the fuses on the amp and car.
Apr 10, 2014 | Kenwood Car Audio & Video
Stereo install yukon w amp and subs
Recheck your connections from deck to "non-sub" speakers. Are you using an adapter from deck to vehicle wiring harness OR are all wires individually connected?
Apr 09, 2014 | 2002 GMC Yukon
Is there a deck I could put in a 1994 Oldsmobile Cutlass Ciera for use of subs?
i have a kenwood cd player i installed in mines with amp and 15 inch sub woofers in mines
Sep 01, 2012 | 1994 Oldsmobile Cutlass Ciera
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
I got the same problem since thair is no sub out for this deck
Hello livinglifeas,
You can connect the regular preamp outputs to a sub amp. Dedicated sub outputs will normally have a built-in crossover whereas the regular front/rear preamp outs will be full-range. Just make sure that the amp you use for your sub(s) has a "low pass" filter.
Hope this helps.
Jun 16, 2009 | Dual XDMR7710 CD Player
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
Subs, amp, wiring or cd deck problem
It sounds as though you have probably blown the output transistors in the deck. Please note that if any of the spkr wires touch each other or touch the radio or amp chassis or if they come in contact with the metal body of the car that this creates a short circuit conditon and will destroy the deck and or amp. the fact that the amp still turns on and you have little or no output is an indicator of blown output transistors. The burnt plastic smell is another indicator of the same thing.Spkr wires and terminals must always be thoroughly insulated. Good luck and please don't forget to rate.
Apr 08, 2009 | Car Audio & Video
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Sub not working after installing the jensen vm9022 deck
Nov 19, 2008 | Car Audio & Video
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Alpine CDA-7892 CD Player Logo
1,306 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
