Question about Everex StepNote XT5000T Notebook
Window corrupt my computer i turned off turn it back on and it said that it was corrupt and i need the set-up disk to repair it do not have the set-up disk what do i do now
    Genius:
  • 1,124 Answers
Check first if your computer does have another partition with a recovery disk.
If yes, run the setup from there (see the option at the start up F10 o F12 or your system recovery boot key)
If not, you will need a Windows CD to reinstall the system.
Posted on Nov 05, 2008
Computer won't turn on it say's \WINDOWS\system32\config\SYSTEM---Windows could not start because the following is missing or corrupt: You can attempt to repair this file by starting Windows Setup using...
Borrow that CD-ROM from any friend who does have one -- you don't need to have your "original" disk.
Or, telephone eMachines, and order a replacement set of "System Restore" disks.
Probably $20, plus $20 for overnight-courier shipping.
Feb 19, 2011 | E-Machines eMachines Desktop PC
I just turned my computer back on and it says disk boot error and wont get past that. Ant help would be great!
Your Windows installation on your computer has become corrupted, you may want to try to recover your personal information, a technician will be able to do this. It might be possible to repair windows by way of the windows disk. However it mostly comes down to formatting the hard drive using file system NTFS and reinstalling your Windows operating system.
All the best, thumbs up!
damnor01
Nov 08, 2010 | Computers & Internet
Turn on, then shuts down and power up again, over and over...
Your Windows installation has become corrupt. For Windows Vista or Windows 7 you will need a system disk to repair it--just boot from the disk and follow the prompts to "repair my computer."
For Windows XP, you can use this fix: http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Sep 30, 2010 | Sony Computers & Internet
It won't turn on. It shows a black screen with "disk read error occured, press CTRL ALT DEL to restart. Then when you do this it does nothing.
Make sure you don't have any bootable CD/DVDs in it. Disconnect any external USB flash/thumb/hard drives.
If that does not work it is your primary hard drive. Either the data on it got corrupted, the drive is failing or has failed.
The first step is to try to repair Windows. Below is a decent tutorial but you can find more with a web search.
If Windows repair cannot find the hard drive the it has failed. You need to install a new hard drive and hope you have backup.
If Windows repair is buggy and gives you errors of missing data during and after the repair the disk is failing and "forgetting" data. Replace the disk.
Otherwise, repair will fix things so the only thing you need to do is scan for a virus or find the program that corrupted Windows.
Good Luck!
Aug 17, 2010 | Toshiba Computers & Internet
MY COMPUTER DISPLAYS A MASSAGE (c0000135) soon after turn on what to do for that problem
This error c0000135 can be very tedious. It is a Operating system error. Its not a problem with the computer.
This problem occurs when the file "winsvr.dll" becomes corrupt. This file resides in Root partition (Windows/ System32 folder. Usually when you have a corrupt file in Windows OS. It can be repaired by the Windows Installation disk. But in the case of this error you have to install another Windows Operating System like Windows NT, Windows 2000 or even Window XP on the same disk to access the files externally of your own Windows. Then you insert the Windows disk in the computer and repair it. As windows disk asks to repair while booting be careful do not let your Original OS get formatted. There is another method which can be a little difficult specially in the case of laptops that is you have to take out your hard disk and inserted in another computer and access your Windows from the Operating system of that computer and insert your installation disk in the computer from which you installed your Windows and repair it.
Aug 01, 2010 | IBM ThinkPad T41 Notebook
I turned off the Powerstrip last night now this is what I get when I turn on the computer. I think I'm putting in the correct disk yet there is no result. " Windows could not start because the following...
You have damaged "Hives" Windows registry structure. This is a common problem, and is easy to fix microsoft have a Knowledge Base article on it I include the link here for your convience.
http://support.microsoft.com/kb/307545
If you follw these simple instructions, you will get ya PC back.
Jan 19, 2010 | Dell Microsoft Windows XP Home Edition
My pc will not boot up it says windows/system32/ is missing
For that you need recovery disk.
Put that disk in cd/dvd rom.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option then set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with that recovery disk then follow the procedure and choose "R" for recovery console then type in prompt "chkdsk /r"
then press "y
then it fix error on harddisk.
Then resatrt computer then if still same error then again boot computer with disk then choose "r" for repair previous windows then it repairs it.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
Windows wont start up.
Yes you need winxp or recovery disk.
Then boot your computer with that disk.
For that put that disk in cd rom.
Then go to boot option then set first boot device as your cd or dvd rom.
Then save settings then it boot with that winxp disk.
Then follow the procedure you get message when it find your previos version of windows then press "r"
then it repair your winxp.
Let me know if you need more assistanse.
Thanks.
Sep 02, 2009 | Microsoft Windows XP Professional
I closed down the top of my laptop and now its saying repair
sounds like you're windows is corrupted use a windows install disk get to the part where you have choice to install windows or repair it and you can then run auto repair. If possible BACK UP anything you need before this and you will need to run updates afterwards as it overwrites many newer files
Feb 18, 2009 | Acer Aspire 5050-3242 Notebook
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Everex StepNote XT5000T Notebook Logo
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
