Question about Husqvarna Viking 1
My viking serger 905 wont cut
My Viking Serger won't cut the fabric while I'm serging Is my blades dull? Can anyone help
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Posted on Apr 10, 2009
I have a babylock evolve serger. It serges fine w/o the blade engaged. Once I engage the blade, the stitches don't hit the fabric
most Sergers have a blade adjustment that allows you to move the blade closer to the sewing plate as well as further away sounds like yours may be to close to plate. Open the door to the underside of your sewing machine; their should be a round knob at the base of the blade are. Turn the blade until it moves away from the sewing plate. test and see if you have adjusted it enough so as not to cut your stitching off. hope this helps
Jan 11, 2015 | Sewing Machines
Do I have to have the cutting blades on the machine to serge material? Also, what's rolled hem and whats overlock?
No you do not need the cutting blade to serge but you shouldn't have to remove the blade it you should be able to push the knob at base of blade inward or pull it outward to turn blade downward out of the way.
TUTORIAL - How to do a rolled hem on a serger - StitchCraft
http://stitchcraftonline.com/blog/?p=42 - 71k - similar pages Aug 5, 2009 ... One of my favorite uses for my serger is to do rolled hems. A rolled hem is were the machine folds the fabric under a tiny bit and then stitches it.
Jan 05, 2015 | Sewing Machines
My serger won't cut
Sounds like your blades are either dull, misaligned, disengaged or broken. Examine your serger book for how to re-engage the blades. If they are engaged, make sure they are aligned correctly. If that still doesn't help check for damage.
Sep 10, 2012 | Brother 925D Serger
I have a Husqvarna serger and when I try to serge and cut through 3 thicknesses of sweatshirt fleece it won't cut. I have replaced the cutter and it still won't cut. The same happens when I sew on polar...
I really need to know what kind of serger you have , if it is the 905 910 or the 936 series take a look at the large headed screw that holds the knife in place. if you are doing fleece it will cause a lot of build up of lint behind this screw and not allow the knife to go all the way up and down causing it not to cut multi layers of fabric, and if this is the case it probably needs to go the an authorized tech for a thorough cleaning
Oct 21, 2009 | Husqvarna Huskylock Computerized 905
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
User guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Jul 24, 2009 | Husqvarna Huskylock Computerized 905
Need to find compatible presser feet for Huskylock 700
Not really sure but would suggest contacting an authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Dec 27, 2008 | Husqvarna Huskylock Computerized 905
Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Jan 05, 2008 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
341 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
