Question about Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
How to replace motor belt on front load washer
The belt that runs from the motor around the tumbler broke, I bought a kmew one but am having problems getting it to fit. Yes it is the right size belt,I checked that first. Is there some trick to this or some thing I'm not doing right. Any help you can give me would be great.
  • Cathi Bernatowicz Oct 07, 2006
    Thank you for your help. I'll let you know if every thing works out! cathi
  • daniel kidane May 28, 2013
    i need diagram for w westing hause washer
  • 175 Answers
I'm not familiar with the particular model, but most of those front loaders there is a trick to getting the belt on. You put the belt auround the motor pulley first then the left side of the larger pulley. Put it on as far as you can get it to go, then hold it in place while you slowly rotate the big pulley clockwise. If you do it right it should "walk" the belt up ont the larger pulley and the tension should be about right assuming you havent moved any idler pullies or the motor. Good Luck!
Posted on Oct 07, 2006
    New Friend:
For w westing hause washerhi i need to halp
Posted on May 28, 2013
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The tumbler will not turn. What could it be?
My best guess would be that your belt either broke or at least jumped off. If it is just off it may be a bad tensioner pulley. If the you can hear the motor run and it is not turning then something has to be wrong with the belt not driving the tumbler.
Nov 12, 2009 | Whirlpool GHW9400 Front Load Washer
Hotpoint aquarius tumbler not turning belt was off so put it back on and still tumbler not turnig altho bottom motor is working
the belt didn't get put on the idler pulley and does not have enough tension to turn drum, recheck belt routing
Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
The drum bangs against the washer during the fast spin. Pieces of plastic broke off. What could be the problem.
If your drum is belt driven, it may need adjustment. It should run straight from the motor wheel, directly around the barrel circumference. Chec for excessive wear. GOOD LUCK.....ABORN
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Belt on Frigidaire front loader
bingo they run crooked sometimes,,and sometimes there just defective,,if you have the back of already ,,just slip it over motor pully,,,than the tub pully hold wiht 1 hand and turn the big pull with the other...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Tumbler
Try the motor controller, if you bought the unit before 2006 the part should have a 5 year warranty, check your manual. If not in Warranty the part is 178.99 average. The motor controller is in the back right corner of the machine. If you have a ohm meter check the motor for correct ohm readings, easy to do. The tech sheet inside the machine ( left side behind kick panel in a brown envelope) has the test procedure and ohm readings.
Jul 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Open Questions:
See all Frigidaire FTF2140ES King Size Front-Load Energy Questions
Washing Machines Logo
291 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
