Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Transfering from camera to Windows Vista
I Connected the usb to computer and it says that its connected but the camcorder says connecting in a blue screen.... my camcorder takes the little discs
Ok its a DCR-DVD108 i finalized the disc and inserted it into the drive of my computer but it is in VOB format i need some sort of program to make it MPG compatible so i can edit the film any ideas?
Posted on Nov 05, 2008
  • 10,594 Answers
Please mention camera model to help you out for Window Vista driver update.
Driver for dcr hc 62e
Windows 7
* Drivers:
o The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
* Not Supported:
o The USB streaming feature is not supported with the Windows 7 operating system.
o The Windows 7 Starter edition is not supported.
Windows Vista
* Drivers:
* Not Supported:
o The USB streaming feature is not supported with the Windows Vista operating system.
o The Windows Vista Starter edition is not supported.
* View Detailed Windows Vista compatibility information.
Windows XP
* Drivers:
* Not Supported:
o The Microsoft Windows XP 64-bit operating system is not supported.
o The Windows XP Starter edition is not supported.
Mar 09, 2011 | Sony DCR-HC28E Camcorder
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
Nov 07, 2009 | Sony Handycam CCD-TRV67 Camcorder
Camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 20, 2009 | Sony Video Cameras
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
Option 2:
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
Option 3:
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Compatibility with Windows Vista
you cannot use usb connection on vista with this camcorder if you want to transfer videos from tape. use a firewire or an ilink cable and windows movie maker to capture videos. no drivers needed.
Mar 14, 2009 | Sony DCR-HC42E Mini DV Digital Camcorder
TRANSFER TO PC
Hook up camera let windows say find new hardware. FOllow the prompts. Acording to Sony Xp has the driver already unless it is a 64 bit. See Below:
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC21&SelectOS=31
Dec 21, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Nov 07, 2008 | Video Cameras
Sony handycam DCR-TRV330 Software
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV330&region_id=1
Driver information for Microsoft® Windows Vista® and Windows® XP
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver. Check the Updates tab below to see if any updated driver is available.
  • Starter and 64-bit versions of the Windows Vista and Windows XP operating systems are not supported.
Apr 20, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
87 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
