Question about RCA WSP150 Main / Stereo Speaker
RCA WSP150Where can i have them serviced
Sound is weak where can i get service Are circuit diagrams available?
  • morriskurman Nov 05, 2008
  • morriskurman Dec 28, 2008
    Your suggestion is the best one that has been suggested. However there are many questions,
    Do you do it? What is the cost? Shipping becomes a big part of cost. Will the rieceivers receive the signal from the transmitter
    I purchase the Wsp 150 from E-BAy when the price is right. So far i have a few . I have been lucky, as a few of them work. Never a problem with transmitter.My wife and I are both a little hard of hearing, so they do serve a purpose.
    Thanks again If you have more info ,please inform me.
    Scholar:
  • 51 Answers
Most of this newer stuff is disposable. Chances are, most of the sound circuits are on a single processor chip with a cryptic house number instead of the actual part number. A shop would charge more than the cost of a new system, and you probably couldn't get the parts to repair them yourself. If you're really attached to the system, your best bet is to replace the entire amplifier section with a new generic module, and rewire as needed. Parts Express and MCM Electronics probably have suitable amp modules.
Posted on Dec 27, 2008
  • BarryMusic Dec 28, 2008
    Unfortunately, my specialty is Classic Car radios (very old stuff) and high-end Avionics (my day job, and cutting-edge technology). Your system falls into my "not really sure" window between the old and the new. It can certainly be done, but you're better off buying an entire new system in my opinion. The amplifier substitution trick is something I might try if I found the system for free somewhere, but not a job I would want to take in, as it may require much time spent experimenting. Thanks just the same for considering me to repair it.
I have an RCA proscan tv, CRT type. My sound has to be turned all the way up to hear it. There is also a low hum whether the sound is up or down and does not change volumn, no matter if the sound is
The ctc169 was the workhorse of the RCA line being used in over 300 models----sounds like a possible audio output circuit---a lot of parts are no longer available and I would be careful having a shop fix a set this old.
YOU "might" be able to get around this with a surround sound system used with a cable box.
Dec 04, 2012 | Televison & Video
When I open my RCA TV 25648 it shut down after a few second. Is there any way to fix it ? Thanks
IF LED IS BLINKING then............. usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact RCA service centre.........
Apr 21, 2011 | RCA F25648 25" TV
27f530t not powering on power to switch but not on
IF LED IS BLINKING then following is the situation..............
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place....... IF LED IS ALSO NOT BLINKING then following is the situation............fuse is gone due to deffective component in power section ....BOARD HAS TO BE CHECKED.............. so my suggestion contact near by TV service engineer or approach RCA service centre ....this problem cannot be solved by user unless user is a technical person, having idea about components (resisitors,transistors, diodes, ...etc), having tools like multimeter ,soldering iron , soldering lead ,flux, desoldering coil, etc....
Apr 14, 2011 | RCA 27F530T 27" TV
I need the circuit diagram for a Thomson cordless telelphone model CE21828GEX. lightning damage on the base unit.
No detailed service information was ever available for GE/Thomson phones, so there is no diagram available. When under warranty, the phones were returned to GE and replaced. Out of warranty, the only parts available were complete boards. At our shop, we would occasionally track down and repair power problems by tracing out the board, but this was usually just an exercise in futility. These phones were never meant to be serviced.
Nov 12, 2010 | GE Lands Phones
I have an RCA T52P52937 projection TV with no sound
1. The sound circuit of the board has a possible weak capacitor or
(RC) resistor/ capacitor circuit that has become weak is not working and your tv unit needs service but without a schematic and a meter you will not be able to determine the malfunctioning component.
Aug 02, 2010 | RCA Televison & Video
When I turned my TV on I can hear the sound but get no picture. I have unplugged the Direct tv box and no change. It worked fine yesterday.
Most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | RCA L32HD31 32 in. LCD HDTV
Circuit diagram
You won't find that here and Dell may not even release service info to individuals; I had a business with monitor repair as one of my most frequent repairs - well, until the Chinese could make them cheaper than I could repair them. And, unless you have some training in electronics, a few pieces of needed test equipment, the service literature probably won't help you much. I repaired in excess of 2,000 monitors and had service literature on exactly three models.
If you care to describe the problem you are having, I can probably give you some tips although the first one I'll give you now; unique parts in that unit will not be available any more. Standard semi's are easy but the flyback and any programmable ICs may not have ever been available except to authorized Dell service centers.
May 20, 2009 | Dell E771p 17" CRT Monitor
Dead power supply pcb in Toshiba laptop model ps225a
Those are "non-serviceable", therefore no circuit diagrams are available.
Mar 18, 2009 | Computers & Internet
Sound, no picture.
Problem might be in your Video processing cirucuits. if the picture cracks time to time. there might be not a big problem present as it is due to weak wiring and circuit dusting. if there is no video completely then the problem in tuner,video if sections,deflection circuits. Contact service engineer as it may not require any rectification from user part
thank you !
Dec 20, 2007 | RCA F36650 36" TV
RCA WSP150 Main / Stereo Speaker Logo
233 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
