Question about HP DesignJet 1050c plus InkJet Printer
What does system error 0B0007 mean
When i turn it on it starts to initialize and the comes up with the error 0B0007?
Thats mean that it is unable to detect the vacuum fan
Posted on Nov 26, 2008
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Controller monitor failed,controller not started appeared on my screen when i opened our server systemx3500
This is a raid controller failure. Server is not able to initialize device.
Workaround:
1: Turn off server
2: Take out Raid Controller from server > blow air on raid controller slot to remove dust.
3: Put it back
Now turn on server and see of it gets initialized.
If you still gets error then its time to replace controller
Thanks
Dec 06, 2012 | IBM System x3500 7977 - Quad-Core Xeon...
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Enteri am having a big problem with my acer 5315 laptop it keeps coming up with a blank black screen and at the start screen after logo it says windows failed to start. a recent hardware or software change...
I might advise you reformat the operating system of the computer, or check the peripheral devices for this computer if properly connected? You got a fatal error it means that there is something that is not reading by the memory of the computer.
Mar 16, 2009 | Computers & Internet
F61
To my knowledge, an F61 error is a blown fuse. A workaround is to replace the fuse with the same value but specify slow blow.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Panasonic SC-AK24 CD Shelf System
HP DesignJet 1050c plus InkJet Printer Logo
948 people viewed this question
Ben Johnson
