Question about Sony PlayStation 2 (PS2) Console
Level change I want to change the level setting on my ps 2 but there is not setting button. I put my dvd in and then it says there is a parental control on this would you like to continue yes or stop. i hit yes and then a smaller screen comes on and says that would you like to "temporarily" change the level to 4. Yes or No? i hit yes and then i have to put my password of 0000 and then it works, but if i hit no then it goes back to the red screen with yes or stop. how do i get rid of the parental control and all together.
  • 488 Answers
Here it is:
Step1
Place a DVD that prompts you for your password in your PS2. If you have any R rated DVDs sitting around, one of those should work just fine. It should prompt you for the password before anything else comes up.
Step2
Select "Yes" to playing the movie and select "Yes" again to temporarily suspend parental controls. This is where you would put in the password if you knew it and the DVD would play. You may try "1111" at this point, as it is often the password. If that doesn't work, continue through the next few steps.
Step3
Press the "Select" button on the screen that wants you to input the password. This should change the text on the screen from "Enter Password" to "Delete Password."
Step4
Input the numbers "7444" into the box on the screen. This is the universal password needed to delete the current password. Once you input the numbers, you should get a message that says "Deletion Complete." Press the "Select" button again and you should be prompted to enter a new password.
Step5
Enter a new password for your parental control. Make sure it is something easy that you will remember. Once you enter it in, you will be asked to confirm your new password. Enter it one more time and you should be able to watch any DVD you want.
if it helps please rate positvely!!
Posted on Nov 07, 2008
How do I change the zone on my Soniq E32W13D-AU?
You should have got a red card with the AU and NZ customer support numbers on it. If you phone them, they will tell you how to unblock the player to make it region free.
On the Soniq QV191LC TV and DVD player, you follow these steps. It may work for your model but if it doesn't, try the support line.
1. Switch on
2. Switch to DVD mode (use Source button on remote)
3. Select DVD setup menu (press DVD button on remote)
4. Select Preferences page (use > key on remote)
5. Press '0' key 4 times on remote: the Region Code menu will appear
6. Use up and down on remote to select region (0 of course)
7. Press exit button.
You should now be region free.
Try these numbers:
AU 1300 765 663 / (61) 3 9543 5111
NZ (64) 9 2667512
If it's any help, you can download the manual here:
ftp://ftp.quatius.com.au/Manuals/E32W13D-AU.pdf
Jul 31, 2014 | Sony Playstation 3 (PS3) Console
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
We have forgotten are pass code for our PS 2 how can we reset so we can watch DVD's ?
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings. Source(s): http://www.techlore.com/article/10505
also generic code is sometimes 1234
please remember to leave a positive rating and a testimonial if it works.
Apr 10, 2010 | Sony PlayStation 2 (PS2) Console
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Parental codes
Put a DVD into the PS2 and let it try to load. When the screen says chenge to level four select yes. When the entry window pops up,press the select button on the controller. It should say reset password or something like that. Put in 7444. Then when you rename the password put in 0000. You will have to do it again 0000.
Once the movie starts, not the menu screen, but the movie actually playing, Press Select button again. The PS2 DVD menu should appear. Cursor over to the toolbox or Setup, and press X. Cursor over to the third icon, and press X. Arrow down to PArental and press X. Change the Parental lockout to OFF.
I am not completely sure about the procedure here but the numbers are correct.
Nov 11, 2007 | Sony PlayStation 2 (PS2) Console
Parental levels
Put in a DVD, and press select button to go to PS2 DVD menu.  highlight setup menu. Press X.  go to settings I think, and paretal control is there.  Use password 7444.   Usually everyone sets the password to 0000.  Then when you go into the parental settings, turn the level value to OFF
Oct 11, 2007 | Sony PlayStation 2 (PS2) Console
Dvd parental controls
With a DVD disc inserted in your PS2, press the Select button to bring up the on-screen Control Panel. Press the X button to select the Setup icon. Use the directional pad to reach the "Custom Setup" menu, and press the X button. Move to "Parental Control" and select with the X button. A window will appear asking you to enter a four-digit password. Enter your choice of password using the number buttons that appear then enter it again for confirmation. You're now able to set the Parental Control level using the "Region" and "Level" options, and change your password
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
