Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport
Water comes out hot or warm on all wash settings but it is set on cold
  • debra315 Mar 16, 2009
    Same problem.....we have checked the water coming in and
    it is hooked up right. No matter what the water temp is set at
    it comes out hot even when the dial is set on cold.......help!
  • twyb May 11, 2010
    can you give a little more information about the specific part needed?
  • 63 Answers
If its new top loader needs water temp switch need more infor "less soap plz"
Posted on Nov 15, 2008
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool washer GHW9150PW0 and it always washes on hot water, no matter if I set the temperature on cold. I turned off the hot water faucet and still the wash comes out warm. What is the problem?
these washers sense the water temperature that comes in to them and automatically adjust the temperature by turning on the hot and cold valve on make sure both your water valves on the wall are on all the way and water is coming out of each
Aug 19, 2010 | Whirlpool GHW9150 Duet Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Only hot water in washer on all settings
Are the hoses connected to the correct inlet valve on the machine?
If so, then the inlet valve itself may be faulty.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whrlpool frnt load washer is using hot water in evry setting
Did you check to see if the hot and cold are hooked up backwards? Try switching them.
Apr 20, 2009 | LG WM-2277HW Front Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WATER PUMP
your water valve is bad replace that and you will be set to wash cloths again
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal De
