Question about Maytag MER5775Q Electric Kitchen Range
Too hot The oven gets too hot - the thermostat isn't turning off when it hits the control temperature. The temperature reading seems okay. (Model MER5755QAQ). Thanks.
  • 1 more comment
  • weissnest Nov 05, 2008
    The display shows the actual temp inside the oven
    The actual temp goes higher than the temp that it is set for.
    My guess is that the temp. will keep going up well above (100+) the set point- I cancel it (turn off the oven) before it gets too hot, The sensor doesn't read above the set point, but if I cancel and set at a much higher temp, I can see that the temp. is at least at the much higher set point without any additional time to heat up.
    Scholar:
  • 62 Answers
More than likely if it isnt shutting off when it reaches temp. then it probably needs a temp sensor or a EOC (electronic oven control). I have replaced many of these boards in the past , usually there is a relay on the board that is stuck. The relay really isn't replaceable and the whole board needs to be replaced. Does the dispay show the temp that the oven acually is or the temp it is set for?
Posted on Nov 05, 2008
  • 1 more comment
  • Steven Haney Nov 05, 2008
    is the actual temp that it is showing higher than the temp you set it for?
    If you are inclined to do so you could check to see if the element is still getting voltage, if it is then it almost has to be the board, if it were the sensor it wouldnt sense the actual oven temp. Is the actual oven temp way higher that the set temp? like 100 deg.+ higher or is it just 25-50 higher?
    My money is definitely on the board. Again if the sensor is showingthe actual temp the the board is not turning off the heat when it should. Most likely the bake relay on the board is stuck. Either way you would need to replace the board.
The oven wont get hot, it will warm up and the broiler seems to get hot??
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, you will have to test the element for resistance across the 2 ends , with the meter set on the 200 scale if you get a good reading like 000 it would indicate that the part may be ok but if yoiu get a reading of a 01 or a 1 or lomething like this it would indicate tha part is bad then you need to replace it
However you will also want to
First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. It won't broil
Apr 11, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • May 26, 2009 | Kitchen Ranges
    Maytag MER5775Q Electric Kitchen Range Logo
    160 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
