Question about HP Compaq Presario 2200 Notebook
Hard drive failure compaq presario 2200
The laptop was working ok earlier on but the next time I switched it on this error :pxe-E61 media Test Failure, check cable ; came on.
I replaced the old hard drive with a new one but still getting the same error. I went into the BIOS run a self test, result was NO IDE on computer
  • kunigunda Nov 11, 2008
    My mother has this model and it will not boot up. I'm not sure the message she got was the same. She called the help desk and they told her the hd was bad. I would like to replace it. Is there a replacement hd I can get that is relatively easy to install that I could do myself? I have minimal experience though have replaced a couple of dvd drives. THanks.
    Genius:
  • 1,124 Answers
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Posted on Nov 05, 2008
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 26, 2011 | HP Compaq nx9030 Notebook
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
WEN MY COMPAQ CQ60 STARTS UP IT SAYS PXE-E61:MEDIA TEST FAILURE, CHECK CABLE.. THEN IT SAYS PXE-MOF:EXISTING PXE ROM THEN SAYS INSERT BOOT DISK AND PRESS ANYKEY I DNT HAVE A CLUE WOT THIS MEANS CAN ANY1...
Usually it means your hard drive has crashed.
The PXE is your computer trying to connect to a network server (virtual hard drive).
Did you have any important files on the computer?
Oct 16, 2010 | Compaq Presario CQ60-220US PC Laptop
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
I have a problem geting my recovery disc to work in my compaq presario 2200 laptop, as i have just installed a new harddrive iam getting a PXE-E61: Media test failure and PXE-M0F Exiting PXE-ROM. ldygolfer
You need to change the boot order in the bios.
When you start the computer screen should prompt you at the bottom with something like:
F2 or F10 to enter setup.
Once you're in the bios, change the boot order to cd / dvd first.
Right now it's trying to boot through the network, that's why you're getting that message.
Let me know if you need any more help.
Best of Luck!
Feb 24, 2009 | HP Compaq Presario 2200 Notebook
Changed cooling fan in compaq v2403nr laptop. Now it won't bootup
Was your cd drive detected in the BIOS? Take the laptop back apart and double check your connections.
Feb 15, 2009 | HP Compaq Presario V2403NR Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP Compaq Presario 2200 Notebook Logo
292 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
