Question about Rockford Fosgate Punch 700S Car Audio Amplifier
Amp gets very hot in as little as 5-10 min.
I got rockford fosgate 700s amp powering two 12"jl w1v2-8 with an rms power of 150w each. don;t know why it gets very hot. please let me know thanks.
    Problem Solver:
  • 7 Answers
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Posted on Nov 06, 2008
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
Which amp goes with 2 jl audio w3v3 4 ohm
Choosing a amp isn't always easy but it first begins with what you want.
--RMS of the speakers is what you want to use to find your amp.
That's going to tell you what watt's your speakers can REALLY handle @ 4 ohms.
--Also what you want to spend $$$ will determine how clear it sounds.
--I prefer a Rockford Fosgate amp for base and kenwood for highs.
--Also look at the RMS watt's rating to find the proper power and go a bit beyond what you want so that the amp performs with ease.
--Last but not least you chose the amp for how many speakers you are going to connect to that amp. For example if you are using 2 JL audio 12" for subs, then a mono amp is perfect. But if you are connecting 4 speakers, you should begin to find the amp with four channels so that you obtain left, right , front and rear sound.
Mar 16, 2010 | Jl Audio Car Audio & Video
I installed a sony 600watt amp and it works but old rockford fosgate 200 hit harder how do i make my amp louder and evenly spread throughout my car
Hello jmanbutt99,
The old Rockford-Fosgate was probably producing the rated power. The Sony is most likely overrated. But, it's supposed to be stable on each individual channel down to 2 ohms and will deliver 65 watts RMS into that load. So to get the most from it, your best bet would be a pair of 4 ohm speakers paralleled to each channel. A relatively efficient speaker like the Kicker 07DS600's shown here should provide pretty good sound.
http://www.crutchfield.com/p_20607DS60/Kicker-07DS600.html?tp=105
These will work with as little as 6 watts RMS and can handle up to 50 watts RMS so the Sony should power them really well. They're 4 ohm so a pair in parallel will present a 2 ohm load.
Hope this helps
Oct 30, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Want my 10s to beat down the block
http://www.crutchfield.com/p_020DPX1155/Clarion-DPX11551.html?tp=115
http://www.crutchfield.com/p_675FRT1500/Rockford-Fosgate-T1500-1bd-Factory-Refurbished.html?cc=01&showAll=N&tp=115
http://www.crutchfield.com/p_136GMAX/JL-Audio-G-Series-G-MAX.html?showAll=N&tp=115
http://www.crutchfield.com/p_57515001BD/Rockford-Fosgate-T1500-1bd.html?showAll=N&tp=115
Here are a few amps at Crutchfield.com you can look at. Notice that the closer to a class D you get, the price more than doubles. I have 2 Kenwood 12's that are 800W Rms, and I have a cheap SPL 1500W amp pushing them. 148.5 Db in a 93 Eclipse, so don't worry too much about the class unless you have money to burn. Let me know if this helps :)
May 25, 2009 | Lanzar OPTI1200D 2000 Watt Class D...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Cold weather blown fuse
You might want to try better quality fuses, or allow the amp to warm up a bit before you start bumping down the street make old ladies angry.
Jun 01, 2007 | Rockford Fosgate Punch 700S Car Audio...
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
Rockford Fosgate Punch 700S Car Audio Amplifier Logo
292 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
