Question about Pioneer Televison & Video
After the storm in Ryde, last April my Pioneer DVD recorder DVR5404 is gone. My friend electrical engineer sad me that is gone power supply. Tel me please where can I bring my DVD recorder for repairing. I am living in Ryde, 2112. Regards, Fahir Zecevic
5 Suggested Answers
SOURCE: DMRES10 does not power up, caught in an electrical storm
Do not take it in a service center, buy the newest release "EZ" series. "EZ" series has a digital receiver built into it, which is called an "ACCU-Tune". The receiver will swith to analog if the digital skips a beat in reception. The cost to repair your's will be a flat rate of $269.00 at Panasonic's main repair shop. For the above repair, invest in EZ and get extended warranty. My ES10 will not power up, I found a capacitor split on top in the power supply area.
Posted on Sep 06, 2007
donutty
  • 22 Answers
SOURCE: recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Posted on Jan 11, 2008
SOURCE: Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Posted on Apr 16, 2008
  • 230 Answers
SOURCE: "could not repair disc" after power outage
If this happened after a power outage and not a hit/drop then it's probably fried the board to the hard disk, you can often get another board from the same model drive and fix it, by swapping the boards over.
Posted on May 25, 2009
ricomun
  • 24 Answers
SOURCE: No Power after an electical storm
It is very likely that a fuse has blown inside the unit. If you have warranty on the device you should get the manufacturer to replace it. However if it's out of warranty and your not afraid to open up the case of a DVD player you should be able to unplug the unit. Remove the screws and then look for a small glass type fuse located on the main board of the DVD player. It will have two tin ends and a glass tube in the middle. Remove it with a small pair of pliers being careful not crush the glass tube. Replace it with the same type of fuse with the correct voltage and amperage.
Posted on Jul 13, 2009
No power
First check, the AC line where you plug your DVD.Then, check the power cord ,If nothing is change. open it,check the power supply section. checthe power supply section.
Aug 25, 2010 | Pioneer DVR-320S DVD Recorder
Jul 13, 2009 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
I cannot record copy-protected tapes to DVD on my RCA DVD recorde
Here is a link to the installation guide for your Pioneer model - refer to every bit of information on p. 29 (which will refer you to some pertinent info in Ch.1): http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/98391312Installation%20Guide%20DVR-810HS.pdf
If it will not permit you to do the recording:
You have to use a backdoor method. Inspect your TV and see if it has a yellow jack labelled video OUT or monitor OUT - many TV's do not have them. If you are one of the lucky ones that has a video OUT:
1) Connect a VCR to one of the televisions inputs.
2) Connect a red, white and yellow cable from the video and audio OUTs of your TV to either INPUT 1 or 2 on your DVD recorder
3) Make sure that your DVD recorder is set to either INPUT 1 or INPUT 2 - reading the manual for that model is driving me up the wall - I would change the channel on the DVD Recorder (not the TV) to 2 and use the channel down button until it says Input 1 or Input 2 - whichever the appropriate choice is
4) Play the VHS tape and make sure that you can see the picture on your television screen.
5) Press Record on the DVD recorder
Good luck- I would go insane trying to use that Pioneer - it is user-friendly, but not techie-friendly.
-Tha Mp3 Doctor
Jan 07, 2009 | Pioneer DVR-810H DVD Recorder
Pioneer DVR-320-S is dead.
Well if it is dead and the transformer is getting power then next step is the processor.  Which if it is dead, then I am sure all the internal components are as well.  My recommendation is have a professional give you and estimate and buy a UPS unit that will regulate the power to you important expensive units such as this.
Jan 06, 2009 | Pioneer DVR-320S DVD Recorder
Wrong region code
You have to unlock it somehow but i would suggest you return it to the shop and ask
Nov 01, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Can not read the disc if recorder is disconected before finish finalize
what do you mean the power went out if it did while the disc was burning then the disc is now a coaster (no good)
Feb 06, 2008 | Sony RDR-GX315 DVD Recorder
Pioneer vsx 808 rds poweroff?
Could be lots of things, could be the tray not fully loading, or power supply problem...
Dec 03, 2007 | Pioneer DVR-520H DVD Recorder
Aug 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
49 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
