Need help hooking up my canon MP 240 tp my pc.My pc detectsthe printer then says no printer detected.
    Genius:
  • 1,124 Answers
You need to install your printer first.
If you already have installed your printer, do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
If you don't have installed your printer do this:
Get your printer software from: www.canon.com
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Posted on Nov 06, 2008
Can't Install Pixma MP 240 with CD ROM
You can download the appropriate drivers from Canon's web site using the following link:
http://software.canon-europe.com/products/0010645.asp
Apr 28, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Tip
Error P22 CANON PRINTERS MP 240-250-260-270-280
If appears error P22 at this printer CANON MP 240-250-260-270-280 means you need to replace first the scanner,if the problem persist you need to replace the logic board.
on Apr 06, 2011 | Office Equipment & Supplies
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
May 18, 2011 | Cannon Office Equipment & Supplies
How can the pixma mp 240 be reset after refilling the ink tanks? Thank you. RJ
Hi rjwebb77,
Here's the steps to reset your canon PIXMA MP240.
  • The printer is turned off and plugged the power cord.
  • Press the button STOP / RESET and hold, then press and hold the POWER button.
  • POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
  • Release both buttons simultaneously.
  • The printer will proceed in a while (a while), then the LCD panel will show the number zero (0)
  • The computer will detect NEW DEVICE, Ignore it .....
  • Press the power button, then the printer will die.
  • Press the power button again, then the printer will be lit and ready for use.
Hope this helps you out!
Good Luck!
Mar 15, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Hi, my laptop isn't recognising my canon MP240 printer - when I install the cd it doesn't recognise it and says to check all connections and try again. I've tried it now on 3 different computers and it...
try to make a new downloading from the canaon site and reinstall the software, then connect to detect and install.
So check this link for help:
www.canon.printer.com/Pixma-MP-240.us.html
www.techspot.com/???drivers/???driver/file/information/???1089
www.driverscollection.com/????H=PIXMA%???20MP240&???By=Canon
Sep 28, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Pixma mp 240 does not recognize cl 211 and 210
Hello , i have the same problem but vice versa. i bought my printer with the 210 and 211 cartridge and i bought now the 510 and 511 and the printer wont recognize them . all i know is that my printer is specially made for canada thats why it works only with 210 and 211 , so urs must be european because 510 and 511 are the cartridges for the european version of this printer . i've tried so hard to trick the printer so accept this cartridges but its not working . did u find a solution in the mean time ? i could really use some advice
Jul 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I lost my installation software for my canon Pixma MP 145 printer. Please help me to snstall
Hanif, Go to
http://www.bioticaindia.com/pixma-mp-145.html
and download the necessary drivers and burn a CD for future.
Connect the printer to the PC and Allow Windows to detect it. When it asks for drivers point to the directory where you have downloaded the drivers.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I need to download the software/Canon Pixma MP 240 series printer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=17161#DownloadDetailAct
go to this site and put in your operating system and you will get the drivers you require. I would uninstall the all of the older drivers reboot then install the new drivers. Remember not to connect your print to your computer until the new installing driver tell you to.
Hope this does the trick for you, good luck. Please leave a rating, thank you kindly
Apr 27, 2009 | Canon PIXMA MP240 All-In-One InkJet...
74 people viewed this question
jasbo
jasbo
