FixYa.com
Tags:
RCA 32F531T 32
Tv doesn't come on
posted by kingm316 on Oct 06, 2006
i recieved a rca tv model g35302wk and when i first got it it would turn and go off a few seconds later. if i waited ten minutes and tried again it would come on and go off the same way. but now it doesn't do anything when i push the power button. i checked the fuse and it is good but on the bottom of the circuit board i found a few solder joints that have a bunch of brown stuff around them and on top of the circuit board i noticed that around the some of the smaller capiciters looks like it was stained by something. i didn't see any capaciters popped though
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 06, 2006
Helpful (85)
jomaru
Rank:Guru Guru
Rating: 87%, 432 votes
The brown stuff you see is excess flux and is not hurting anything,you need to check the horizontal output transistor for a short,sometimes this transistor goes bad because loose conections in the horizontal driver transformer and could have been intermitant,if the transistor is shorted it likely took the safety resistor that gives him the volts to operate.It seem you are familiar with tv service but some measurements need to be made with a meter to check for a short.If the transistor is bad it need to be replaced with an exact replacement,check for loose conection anyway very carefully,some are hard to see.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
RCA 32F531T 32" TV
I don't have the remote and fpa...
I have an rca 20' truflat tv Answer This...
RCA 32F531T 32" TV
RCA Model F36665 YX2
clicking,w/no sound or pix is... Answer This...
RCA 32F531T 32" TV
problem with it turning on and...
can't find the service # but... Answer This...
RCA 32F531T 32" TV
Double images
Sound is good but images are... Answer This...
RCA 32F531T 32" TV
parental lockout
have uncles tv and there is a... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
