Question about Medion md40298 Notebook
Laptop not recognizing CD drive F
My Medion Laptop (about 3-4 years old) has stopped recognizing the CD/DVD drive. The icon does not appear when a disc is in place. The drive opens/closes and when a disc is inserted it 'appears' to be reading as you can hear it 'whirring' and the light flashes. Once this stops, that's it...nothing. When trying to copy files onto a disc it does nothing. When trying to play a CD or DVD, once again nothing.
I've had a look in the device management files and noticed that there is an exclamation mark in yellow over the type of driver. The driver is a Matshita DVD-RAM UJ-8315. In properties is has a remark that says it "cannot load the device driver for this hardware. The driver may be corrupted or missing (code 39). I've tried to do a troubleshoot, but it didn't help.
Any ideas or solutions to this. I have no idea when this problem happened as I haven't had to use the cd drive for quite a while.
Thanks so much for any help
Keryn
  • keyza15 Nov 05, 2008
    thanks Mike, I have already tried solution no.2 to no avail. I will go to Medion site and check.
    Thanks
    Keryn
    The Medion site was not helpful, but I did find that there was an error 39 against that exclamation mark and after doing some searching, found it had something to do with the registry. Windows had a help section on this and I was able to rectify the problem in the registry manually and now it appears to be working fine. Thanks for your support
    Genius:
  • 1,019 Answers
the yellow exclamation mark, states that the device is not functioning correctly.
options are:-
1:) go to the manufacturers website, and see if you can download a driver for this.
2:) try uninstalling the device, reboot and see if the device manager, finds new hardware, if so reinstall the device drivers.
3:) eject or remove the device, re-insert ( possible dirty-bad-loose Connection.
Mike @ Compurepair.
Posted on Nov 05, 2008
    President:
  • 1,257 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
My laptop's dvd writer does not works. it doesn't read or write any dvd/cd disk. please give me a possible solution... pramod kumar
Check to see if your laptop recognizes it. Right click on 'My Computer' and go to properties. Click Hardware and go to Device Manager. Click on CD/DVD and see if you see yours in there. If not, you will need to get drivers for it.
If you see it, try restarting the laptop. Aside from taking the laptop apart to reseat the drive, it will need to be replaced.
Sep 13, 2011 | Acer Aspire 4315 Notebook
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Drive is on the computer but won't play
you need to replace the dvd drive, you dvd player is faulty, it happens a lot with laptops, mostly after about 3 years they go faulty and ether the cd reader or dvd reader stops working.
Aug 16, 2009 | HP Pavilion dv4-1140go Laptop
CD drive is not detected or recognized
i think your cd/dvd drvive's lence has problem, can u chk it in any other machie.
Jul 15, 2009 | Computers & Internet
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My Laptop no longer recognizes that it has a DVD/CD drive
If you can, remove unit from laptop and start laptop without CD/DVD. It is usually fairly simple to remove. Maybe a few screws in bottom of laptop. Cut off laptop and reinstall. Restart and windows should find it.
Jun 28, 2009 | Acer Aspire 9300-5349 Notebook
Cd drive not recognizing cd's
nope it happens to me, if your laptop still under warrantee call toshiba and they will replace it to you. the problem is the lens not reading the cd, try to clean it by dvd cleaner if its not working replace it.
Mar 19, 2009 | Toshiba Satellite M115-S3094 Notebook
I have a Dell desktop computer in my home office that is about 2-3 years old. It has a CD/DVD drive that is suddenly not working. The disc drive has disappeared from the options on "My Computer" and isn't...
Hi
Yes it is a common problem with Dell machines. Try right clicking on the icon in My Computer and selecting 'eject' If that does not work then just buy a new one and install. It is a straightforward job. just make sure the jumper connections on the new player are set the same as the old one
Dec 08, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
Medion md40298 Notebook Logo
919 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
