Question about Zhone 6211-I3-200 Router
How configure router for port used with p2p software?
I need to connect with p2p software, but this require a open port in the router; How I can perform this task?
  • edhing Nov 06, 2008
    I can not login because username or password is wrong.
    My email and others XP users accounts emails shows as optional usernames; I change to admin and use admin as password, but not login.
  • 52 Answers
First, know what your computer's IP address. This should be the computer that has the P2P software installed. (How to do this? Go here http://kb.iu.edu/data/ahse.html)
Then, open your Internet Explorer and type in on the address bar http://192.168.1.1and this should prompt you to login. Just type in admin for both the username and password.
Go to Advanced Setup > NAT > Virtual Servers
Click on Add then Make New One and use the name of your P2P software for the Server Name. Then your computer's IP address for the Server IP (which you have obtained when you did the first instruction).
Then for the rest of info required such as External & Internal Port Start and End and the Protocol, you may refer to your P2P software port configuration.
If you're not sure what it is, check the support website of your P2P software.
Hope this will help. Cheers x
Posted on Nov 06, 2008
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
What is this routers IP address
In the next steps we will configure your router in such a way that the router allows Zultrax P2P to accept incoming connections. Your router is designed to serve multiple computers and of course multiple programs. Even if there is only one computer connected we will later on need two bits of information:
- The local IP of your computer
- The port used by Zultrax P2P
Zultrax P2P can help you to find those two bits of information. In the menu tools choose system info. This will display a page of information with various details about the program amonst which Local IP and port. Write those 2 down, you'll need them later.
It is the Local IP we are looking for, do not confuse the Local IP with the Public IP that is also shown on this system info page.
2.
Exit Zultrax P2P. Don't leave the program running while you are performing the actions below. Leaving the program running might give you false indiciations that your actions where not succesfull. Open a webbrowser (e.g. Internet Explorer, Firefox or Opera). Enter the IP address of your router in the address bar of the browser and press enter. The IP address of your router is by default 192.168.2.1
4.
  You see a box asking your username and password. By default the username for your Belkin F5D5230-4 router is admin and the password is blank
Enter your username and password and click the ok button to continue.
5.
  Click the link virtual server.
You find this link on the left of the page.
6.
  You see a page titled Virtual Server. Enter the fields as follows:Private IPThe local IP address you wrote down earlierPrivate PortThe port number you wrote down earlierTypeTCPPublic PortAgain the port number you wrote down earlier
7.
  Click the button enter.
You find this button on the bottom of the page.
8.
  zultrax_p2p.jpg   Your Belkin F5D5230-4 router is configured now. You forwarded a port for Zultrax P2P. You can start Zultrax P2P and you will see incoming connections coming up. This might be not immediatly after start up but within minutes you should see at least some incoming connections. The program will adapt itself to the new configuration.
In case you still don't have incoming connections, perhaps you also have firewall software installed that needs configuration. For that see the Firewalls/Routers page , the info about firewall software is somewhere at the bottom of that page.
Local Static IP
  IMPORTANT : Depending on your exact configuration it is possible with the Belkin F5D5230-4 router that after a while you might be again without incoming connections. If this is the case, your router gives your computer a Dynamic Local IP Address. Often that is no problem as long as that Dynamic Local IP Address is always the same. As soon as you lose your incoming connections, you can assume it is not always the same.
In this case you can best define a Static Local IP Address for your router. We have a manual for this here.
After you defined a Static Local IP Address, best use the Settings in the Tools menu of Zultrax P2P and change the port number, to e.g. 6347 and afterwards repeat the steps as mentioned above.
We advice you to only do this in case you lost your initial incoming connections again. Otherwise, it is most likely not needed to start making changes in your computers settings.
Oct 18, 2010 | Belkin (F5D5230-4) Router
How do i open my lictening ports on d link
See this site http://portforward.com/, select your router model (or similar) and follow the guide.
Oct 19, 2009 | Computers & Internet
Router slows down radically after a few hours of use
Well that is because torrents and other p2p apps open too many connections and the router can’t handle it. Try limiting the number of connections torrents and other p2p can use.
Sep 24, 2008 | Edimax BR-6104K Router (br6104k)
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
On-Q Home Router - Unable to conenct to VPN
What VPN software are you using? you need to open the port number of that software on the router.
Oct 15, 2007 | ON-Q Home 8-PORT Internet Firewall Route...
Edimax wirless router 6114Wg needs restart to start working
Sounds like a port issue. Follow the below link for more info on port forwarding. This needs to be done for programs like utorrent or emule and many others. http://www.portforward.com/english/applications/port_forwarding/Utor/Utorindex.htm or just check out http://www.portforward.com Good Luck
Sep 27, 2007 | Edimax BR-6114Wg Router (BR6114WG)
FIREWALL ON P2P
There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
Sep 25, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Zhone 6211-I3-200 Router Logo
301 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
