Question about TDK MOJO 256F 256 MB MP3 Player
Can't turn on
I can't turn my TDK Mojo on for some strange reason. A day ago it was fine. Could the problem be that I displaced some internal mecha inside, as I dropped it while I was bending down once? A few hours later when I turned it on, it when ballistic. The song that automatically played after I turned it on fast-played (skipping as in from 0:00 to 1:04 and such) and then when I paused it to scroll to a different folder, it scrolled through all of the folders itself very quickly. A day later, it played fine... Is there something wrong? Or should I take it to a repairman? (oh darn!) Thanks! (I'm really missing it right now...)
  • Anonymous Sep 28, 2008
    it does not work anymore
  • Anonymous Oct 04, 2008
    will not turn on
My van started a couple of days ago and now it wont fire up.
sounds like you may havw a bad ignition coil or a crank position sensor
Nov 02, 2012 | 1997 GMC Savana
I have a 3.5hp 2000# press. washer. It does not generate any pressure to speak of. The last time I used it (2 years ago it worked fine. The spiral wand does not have sufficient pressure to spin.
Over time debris could prevent internal valves from seating correctly. Try displacing water from inside the pump with light oil or wd40 over-night. If the internal parts are not totally rusted, the oil may help. After soaking in oil, adjust the pressure knob to the lowest setting then slowly adjust to full while spraying. May take several treatments. Check the wand for debris/ obstruction at the tip. Good luck
Jul 02, 2011 | Garden
Where would I be able to download a driver for my TDK mp3 player?
http://www.lostmydrivers.com/driver/download/2232/TDK/Cameras-and-MP3-Player-Drivers/tdk-mojo-128f-256f-mp3-fm-player-mojo-software---driver-upgrade. hope this helps
Nov 27, 2010 | TDK MOJO 128F 128 MB MP3 Player
My 2001 Dodge Durango has a strange problem. About 2 weeks ago, the HORN stopped working. It still "Beeps" if I press the Fob for "Lock" so I know the horn is okay. Then, 2 days ago, the CRUISE CONTROL...
that does sound like you need a clockspring,the clockspring will still turn normally with no noises or any indication its bad ,but from what your describing it sounds like its not making connection internally all the time,i have replaced them for the very same reasons u have explained,hope this helps
Sep 11, 2009 | 2001 Dodge Durango
Mecha error
it says there is a mechanical error meaning that there is an internal part no longer functioning yo need a radio
Aug 20, 2009 | 2009 Hyundai Sonata
Mp3 player software freezes on my Vista computer
hi sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
May 24, 2009 | TDK MOJO 256F 256 MB MP3 Player
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
My radio, clock and internal light don't work
The graciousness of a FixYA would be much appreciated; glad to be of assistance.
Oct 16, 2008 | 1989 Toyota Corolla 2 Door
Screen displays..(internal media as...)
Dude, remove the batery, then, connect your mp3 in your computer, select in Windows menu: Format...but format in FAT...not in FAT32..or Ntfs...then, disconnect and connect again...put music...and thats it...¡¡¡ enjoy again...
Bye..
Oct 14, 2006 | TDK MOJO X 128 MB MP3 Player
TDK MOJO 256F 256 MB MP3 Player Logo
37 people viewed this question
Top TDK Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
steve
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
