Question about Vtech Lands Phones
Handsets donot work. outgoing calls not going through. incomiming calls ring but handsets donot go thru. handsets show a connecting on the screen.
  • 728 Answers
Check your connection of the phone to the phone lines and make sure that the cords are connected firmly and that they do not have a short. Try using a different cord and see if that makes a difference. If it is wireless try moving closer to the base phone and see if it is any better. If none of those work, then try unplugging the phone and taking the battery out (if it has one) overnight to reset it and plugging it back and see if that works. It should be fixed then.
Posted on Nov 05, 2008
  • 3,037 Answers
First try unplugging the base unit for at least 10 minutes to discharge the circuitry completely .
if that doesn't work then go with this option
Register the handset(s) to the base by following the instructions in the user's manual under the "Registration and Operation" section.
If you have already registered the handsets, follow the below instructions to de-register. Once complete with the de-registration process, following the instructions in the user's manual to register the handset(s) under the "Registration and Operation" section.
Note: There are two different versions of this unit; please follow the appropriate set of instructions for your version/unit.
If you have a tone/pulse switch on the bottom of base, follow the VERSION 1 instructions: VERSION 1: DE-REGISTER ALL HANDSET(S) (with tone/pulse switch on bottom of base):
1. Unplug power from the base and remove spare battery pack.
2. Hold down [PAGE] while reconnecting power. When the POWER light begins to blink, release the [PAGE] key.
3. Hold down [PAGE] key for 5 seconds. When the LINE IN USE light begins to flash, release the [PAGE] key.
4. The HANDSET CHARGING light will blink 5 times. Within 5 seconds from when it stops blinking, press [PAGE] once.
If you do not have a tone/pulse switch on the bottom of the base, follow the VERSION 2 instructions:
VERSION 2: DE-REGISTER ALL HANDSET(S) (without tone/pulse switch on bottom of base):
1. Unplug power from the Base. Remove spare battery pack.
2. Hold down [PAGE] while reconnecting power. When the base display reads 'Pr', release [PAGE].
3. Press [MENU]. The display will read 'rh'.
4. Press [SELECT] to choose h1, h2, h3, h4 or AL (all).
5. Press [TIME/SET] to confirm.
6. Unplug power from the base, then reconnect power to complete de-registration.
REMINDER: After de-registering the handset(s), follow the instructions in the user's manual under the "Registration and Operation" section to register the handset(s) again.
    Scholar:
  • 155 Answers
Your phone has internal battery in it.remove that battery and then reinsert it after 10 minutes then try.
thanks
  • 6,487 Answers
CAn you please provide us first the model number of this phone so we can help you better....
  • 19,396 Answers
Try unplugging phones from power for ten minutes.
ensure the handset is syncronised with the base.
Model: kx-tg6641. Handsets are not ringing when somebody calling. During ringing there showing line thru bell at left bottom of the handset screen. Silent mode is turned off.
As per the display of your phone, I assumed that the bell is turned OFF that's why sound is not coming out from the speaker.
OK. Go to the handset direct command menu:
Press Menu
Enter code:
#238 (Silent mode 1=on 0=off)
Then Press 'Save'
To exit, press 'Off'
Other code that may help you:
#160 (0-6 Volume)
#161 (Tone)
Sep 01, 2015 | Bell Lands Phones
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
Why cant i use my speakerphone anymore?
Most likely cause is power supply has shorted functions possibly due to overcharging or power surge I suggest openin up one of the handsets to look for burns on board or loose connections also if there is moisture or metal shavings
May 21, 2014 | GE Lands Phones
I am trying to figure out why i cant hear any outgoing or incoming calls?
Hi
The handsets earpiece.Have it checked or probably replaced.
Thank you,
ken
Aug 02, 2012 | LG Chocolate Touch Smart 3G Cellphone &...
Phones were working perfectly. Without any warning the handsets have stopped ringing and calls bypass my base unit answering system and go directly to my provider's answering system. I have a dial tone...
check diversion - You may have set unconditional diversion to voice mail or have it set somehow ?
Maybe provider can check diversion settings
May 07, 2017 | Lands Phones
Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
Aug 14, 2009 | Lands Phones
Phone doesn't ring for an incoming call
pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Feb 28, 2009 | HTC P4350 Smartphone
Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Dec 27, 2008 | Panasonic KX-TG5632 Phone
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
Jun 23, 2008 | NTL VS1500 Cordless Phone
My GE cordless phone won't ring. Everything else is working.
I solved this problem by cycling power off on the base station for 15 or 20 seconds. When it was plugged in again, the handsets started ringing again for incoming calls
Apr 23, 2008 | Lands Phones
Lands Phones Logo
59 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
