Question about Maytag Dryers
Drying time clothes come out damp as it only runs 25 minutes per cycle
  • 67 Answers
You need to inspect the inside of your exhaust tube that comes out of the back of your dryer and goes outside. make sure to check every inch of it
Posted on Nov 05, 2008
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Not drying clothes fully
If you are experiencing problems with dryer heating efficiency and longer dry times, the following link will explain what to do:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Read through the link provided and let me know if you have any questions. I hope you find this information helpful.
Dec 09, 2009 | Washing Machines
My clothes are still very damp after one run in the dryer. I remove the lint every time and check to see if everything is plugged in and not restricted. The dryer gets hot and turns but leaves the clothes...
Could be the timer switch is not giving you the right drying cycle.
Try to change dryer cycles from the one setting that you would normally use to a different cycle and see what happens.
Or if you have a timed type timer switch, put it to 60 minutes and see if that helps. If it does then you may need to replace the timer switch.
Good luck,
I hope this helps
Oct 08, 2009 | Frigidaire Dryers
When clothes are dryed on the perm press cycle either reg dry or very dry, they are still damp. I have to run it through 2 or more times to get them dry. I'm told by Bosch that is what perm press is...then...
You may not be getting sufficient air flow--remove the lint filter and wash it with detergent and hot water. Also clean excessive lint out of the air vents (under the filter too). Don't use 'perm press' if you want things absolutely dry. Remove and hang up before they cool. 'Damp dry' really means 'don't dry' I guess!
Aug 28, 2009 | Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
