Question about Watches
Believe chime springs have been over wound - Watches
  • 196 Answers
The idea of "overwinding" is probably the most common myth in clockmaking. A clock cannot be wound too tight, unless it is wound so hard that the mainspring breaks, in which case the spring becomes completely unwound and will not wind up again. What has actually happened is that the clock is fully wound, but does not unwind because it is not running for some other reason. Letting down the mainspring would have no benefit.
You're correct that the clock was made in 1974. This is far beyond the expected lifespan of the clock. It is possible that lubrication by a qualified clock repairer could get the clock running again, but considering its age, it may be more likely that the movement is worn out, dirty or corroded and needs replacement.
The three keys should be wound all the way, as far as they will go, once a week. This clock should be self-starting when wound, so the fact that it has been sitting wound without running for years indicates a previous problem that prevented the clock from starting and running the mainspring down on its own.
Posted on Nov 05, 2008
It's a 3 key chime and strike clock that chimes every 15 min and strikes hours. for last one month it doesn't chime at 12, 3, 6, and 9 position and the hour strike is not synchronous with min hand
More than likely, there are springs that activate the levers for it to chime, or bong, they may have got jammed up, you can open it up, and see if you see anything like that, if not, you will have to take it to your local jewelry store, or watch/clock makers to have them take a look. You never indicated what type of clock (make or model) so I can\'t be certain. Maybe a ships clock? They may want to charge you for a overhaul of the movement, but you can tell them to just "make it work" if it was running fine before (keeping time well) then an overhaul probably isn\'t necessary. It sounds like something may have got jammed.
I hope this helps !
Nov 16, 2013 | Watches
I have a Revere 913 clock. Keeps perfect time. Westminster chimes only work intermittantly by itself. Can activate chimes manually. It appears that the functions are in order, but will not activate by...
Hello Rterry6517,
Yes... you are right (CLOCKSMITH / movements).
Electric movements (original (telechron chiming type))
are very much the same as SPRING DRIVEN...
(in fact... the ones I have worked ARE spring driven
A CLOCK repair would be the wise choice...
Some people opt for the electronic conversions...
(my opinion they are quite a bit less of the true tones
of a well maintained clock motor and REAL CHIMES.
Carnac the Magnificent
Nov 20, 2017 | Watches
I stop using mi nixon watch " THE 51-30" for a month and now it doesnt work.
Your watch is an automatic type which means that it is a mechanical self winding watch powered by a spring. It is wound up by a weight that moves when you are walking about and this watch must be worn to keep it operating.
If not worn, these watches will stop in 2 -3 days because the spring has run down.
Some automatic watches can be wound using the crown wheel (winder) but if yours cannot be wound in this way, then swing it from side to side gently for a few minutes and the watch will wind up.
These watches thrive on being used.
Oct 27, 2010 | Nixon 51 30 Watch
Pocket watch seems overwound
If you wound the watch and it ran you would not say you over-wound it.
The only way it is over-wound is if you wound it so Hard you broke the spring or broke off the stem.
The fact is your watch has Stopped running.
Seek professional help.
Hope this tip helps.
r/ David
Mar 09, 2010 | Watches
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Dec 26, 2008 | JCPenney Armitron Sport Link Bracelet...
Watches Logo
515 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
