Question about Zenith IQB56W10 56" Rear Projection Television
No picture come out
I have IQB56W10 which works fine until yesterday, when we power it on and found that no picture coming at ALL where the sound works will.
Any Help?
Thanks
  • 1 more comment
  • AABBCCDDZZ Nov 05, 2008
    LAMPS ?
    I have no problems with the picture ever before.
    Are these lamps can be replaced? Do you have any idea how much they cost?
    Thanks
  • AABBCCDDZZ Nov 08, 2008
    You said lamps, are there more than one projection lamp? Please explain
  • AABBCCDDZZ Nov 09, 2008
    Can the three lamps be burned out at the same time?
    Is there any fuse that could be burned out?
  • 153 Answers
Sounds like maybe the lamps have burned out
Posted on Nov 05, 2008
  • 1 more comment
  • Trevor Gordon Nov 05, 2008
    Not sure if it's the lamps, but if it is, they usually are several hundred dollars a piece. Is best to have a local repairman come out and test to see what component has failed.
  • Trevor Gordon Nov 08, 2008
    There are 3 lamps, one per each of the primary colors of red, green, and blue
  • Trevor Gordon Nov 10, 2008
    It might be a power module issue, best to have a repairman put a meter on it and find the exact problem.
Thinkpad T41 with XP-sp3: No sound / working fine until yesterday
Hi. Try plugging in an external speaker just to test the issue. It could be just the speaker of the laptop is having the problem. If you were able to hear the sound from the external speaker then the problem is the built in speaker of the computer. If there is no sound coming out to external speakers. Try to reinstall the driver of your soundcard.
Jun 17, 2010 | IBM ThinkPad T41 Notebook
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Ps2
hold down the power button untill it beeps twice. about 3 seconds which should restart the settings to the default composite settings. from there you can change the settings back to hdmi or whatever you had them at before.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
JVC AV-56WP74
sounds like a power supply7 problem such as a power regulator is bad or maybe the Horizonbtal deflection cu8rcuity is defective. sounds like something if you ask me? should be taken care of by the pros??? Im sorry not being able to assist you better but these sets have hundreds of volts nin them and shoulnt be played with by an unauthoized service company.. Good Luck
May 19, 2006 | JVC AV-56WP74 56" Rear Projection...
Zenith IQB56W10 56" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
