Question about Bugaboo Cameleon Jogger
Help- wheel problem!
It seems one of my inflatable wheels has a hole or is defective b/c it is flat and will not pump up. Suggestions about a patch test or where to order new wheel would be great. it was bought only in june 2006
It is the same as fixing a bicycle inner tube. We levered the tyre off ours with a couple of spoons. Took the inner tube out and partly reinflated it with a bicycle pump. Then dowsed the tyre in a bowl of water to see where the stream of bubbles came from. We marked the hole with a childs crayon, dried the tube, stuck on a bike puncture repair patch and that fixed it. Then checked the inside of the tyre, found and removed the thorn that was sticking through it that caused the puncture. Then replaced the inner tube, levered the tyre back on, pumped it up and away we went. Didn't take long and minimal cost.
I guess the problem arose because we did not notice that the tyres had lost their pressure and so were running flat. Motto - check tyre pressures regularly as you do with a car.
Posted on Feb 11, 2008
Call or email the company. I had the same problem and they sent me a new inner tube for free b/c my stroller was still under warranty (yours should be too). I took the new tube and the stroller to a bike shop where they finished the repair for me for $5.
Posted on Jan 30, 2007
2 Suggested Answers
  • 3 Answers
SOURCE: help- wheel problem!
Send the broken wheel to the company and ask for another. Look up their number on their website for bugaboo.com You might try a local bicycle store and ask them to repair your tire with the leak in it. It will be a lot faster than waiting for a new tire, and cheaper too.
Posted on May 16, 2007
How do I patch holes. There seem to be a couple causing part of the carousel not inflating
I used gaffer tape, seems to work perfectly. Adheres well and it's stronger than the original material anyway. Hope this helps.
Dec 09, 2010 | Carousel Airblown Inflatable Christmas...
Tip
Flat tires
If you have a flat tire before you go to the trouble of taking the tire off the vehicle buy and keep a tire repair kit for tubless tires. If you get a flat, jack up vehicle and find problem with tire. Ninety percent of the time it is a nail in the tire. With tire still on the vehicle pull out nail and follow instructions to put patch in. ( ex. pull nail out. put glue on tool supplied. place in hole. put patch on tool and dunk in glue. Insert patch into hole and twist to insert patch. Cut off excess patch. Your done. Inflate tire. ) This saves you time and money and is as good a fix as you will get at a garage. Good Luck
on Dec 11, 2009 | Ford F-150 Cars & Trucks
I have the quinny buzz and have a problem with one of the rear wheels. It appears to have 5 holes in it (around the inner part that attaches to the plastic centre part, they are very small holes and I had...
hi this is a very easy fix have you searched the web for quinny buzz inner tubes? ebat has loads if you are in the uk
or it is a 12 inch bent valve inner tube my advice is when you have repaired these put in tyre slime
this will help any future punctures by repairing them immediatley and you wont even know
very good stuff had it in mine and never had to pump them up good for any inflatable tyres with an
inner tube
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
One of the back tires on my baby trend columbia stroller is flat. I cant find a hole anywhere. It seems like it may be a problem around the thing that you put air in....any suggestions??
If you pump the tire again with enough air and put your ear against the tire you may be able to hear the air escaping.
If it's a slow leak you may not be able to hear it but any bicycle tire levers will allow you to take off the tire. More than likely you pinched the tube or punctured with a sharp object in use.
I usually recommend replacing the tube completely, the cost & ease of replacing the tube is better than using the patches which I find it a headache to deal with smaller wheels especially for any jogging strollers.
Nov 03, 2009 | Baby Gear
Problem with tires ,air is escaping
Pick up a kit for bicycle repair. Take the wheel off, deflate, pull the wheel from the rim and remove the tube. Pump the tube up a little, place under water and look for the bubbles. Once you find the bubbles, patch with the bike tire repair kit, deflate, put the tube back in, reattach tire to rim and inflate.
Apr 10, 2009 | Bertini Baby Gear
Bugaboo gecko tire flat and tube no longer attached to wheel
First try pushing the valve out while your pumping with bugaboo pump. If it blew out need to call bugaboo you have a two year warranty and they will send you a inner tube or a new wheel.
Tel# 1-800-460-2922
nathalie
Dec 04, 2008 | Bugaboo Cameleon Jogger
Quinny pushchair puncture
A tire can be repaired with a regular bicycle repair patch. Otherwise you can use inflate a flat or tire slime to seal the leak, but you will have to rotate the wheel at a substantial rpm untill the repair sets, perhaps a powerdrill without a bit.
Nov 11, 2007 | Quinny Freestyle 3 XL Dusk Jogger
Fixing a flat tire
Any bike shop will have patch equipment. You need to deflate the tire and remove it from the wheel. See if there is a tube inside the tire. If so, the fix is easy: either purchase a new tube for the tire, or get a patch. Use modelling glue on the patch then press it continually on the hole on the tire for about five minutes until it is dry. Afterwards, re-insert the tube into the tire, reattach the tire to the rim and pump it back up
Jul 13, 2007 | Kolcraft Jeep Liberty Limited Urban...
Oct 06, 2006 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
257 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
