Question about NetGear WGT624 Wireless Router
Can not connect to http//192.168.0.1
When trying to connect to default access I am redirected somewhere else
    Genius:
  • 1,689 Answers
With how you descripbed you issue, there is a possibility that your computer's IP address and the router's IP address are in a different section.
first this you can do is use a HardWired computer (connected tot he router view wire) then access the 192.168.0.1, if it still cannot be accessed, go to your command prompt by click Start, Run, tyep CMD hit OK....on the black window type " ipconfig " press enter and the "default gateway is your router's IP address...
if you have other issues, please lemme know
Posted on Nov 05, 2008
Why not try 192.168.1.1 Goodluck
Posted on Nov 10, 2008
I bought D-Link HHP-W310AV but cannot access to the setup page when type in dlinkap on my browser. Pls help
Enter http://192.168.0.50 in the address field.
By default, Admin will be the User Name . Leave the password blank.
If you still can not access the web-based configuration utility see the troubleshooting guide on page 48 of the manual located at the below web link.Good luck!
http://www.dlink.com/-/media/Consumer_Products/DHP/DHP%20W310AV/Manual/DHPW310AVA1Manualv100WW.pdf
Dec 21, 2014 | D-Link Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I lost my wpa key? Can I find this somewhere?
For that Connect your router to computer with ethernet cable then you can access it with following default link.
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
If your password showing in * or # format then add new password with above method.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 18, 2010 | Belkin (F5D8231-4) Wireless Router...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Continually redirecting farmville
I don't think it is a browser problem.
This may sound scary but do the following
- go to http://www.facebook.com/editapps.php
- click on the X next to farmville
- application removed, click OK
- go to farmville application again, it will ask for access again, click allow
- You will be back to your farm as you left it and no redirecting problems.....
Oct 01, 2009 | Facebook Social Network
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Www.facebook.com redirects to Microsoft Site
That is the default site for facebook. Facebook automatically redirects you to that directory of their site.
Sep 26, 2009 | Facebook Social Network
I have application error 302
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Aug 02, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Gmail is redirected to a blank white page
hi thanks for using fixya!!
Try to update your windows, and your browser. Perhaps, you are havinng slow internet connection.
If you need further assistance, let me know.
Jul 06, 2009 | Google Gmail
Redirecting
Alright, here's a FixYa if I've ever done one. We use a couple of products. This one will tend to knock your socks off, if you only need a single antenna. www.open-mesh.com $50 gets you a wireless router that will do splash screen and redirect. For each element of $50 you can add units. They tend to be private, so if you're gaming via wireless, it's going to be difficult to share the network.
Give it a try.
Carl
Jun 30, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
316 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
