Question about Cameras
Lenses on my S760 camera is broken and keeps capturing black pictures
  • sing2mebaby Nov 07, 2008
    Thanks I'll go right to the Radio Shack and Walmart. Or maybe even all the stores that provide Samsung products. Thanks alot, the http://www.samsungcamera.com/customer/vo... were no help because I have no receipt for this since it was a present from my dad and he would kill me if he found out that I broke my camera, especially since he bought it just a few months ago. He also keeps all the receipt of everything he buys my siblings and I.
    Will hope this works because Xmas is around the corner and he expects me to bring my camera with me for the holidays.
    Thanks alot,
    by Sing2mebaby*
    Genius:
  • 1,689 Answers
There is a possibility that the shutter on the actual camera is damage (this is true if you cant see any physical damage on the lens)
you can have the lens assembly repaired or replace by an authorized samsung technician or in house techs from Radio Shack, Circuit City and even walmart.
you may also have Samsung repair it.
http://www.samsungcamera.com/customer/voc/cus_voc_insert.asp
please do take note, sometimes camera repair may cost more than a new camera...
hope this helps, if you have other questions just lemme know.
Posted on Nov 04, 2008
When i was taking picture the lens of my camera ( sony dsc-w120) become blurd. why'?
The cameras capacity to capture motion pictures is disimpressionful. Usually cameras have feature functionalities either as still picture shoot or motion video recorder devices. Cameras may have any once of the mentioned features or both as complementary for videographic requriements. Inspecte the camera for capacity to capture motion picturee. Usually, the lense capacity with pixel capacities are indication of extensive capabilities. An impressionful camera producign disintergral result requries adjusting the lense or pixles buttons prior to photo shut. Also, cameras that least have the pixel capacity requires photo shoots at still motion or at calm climate least onbracting activities. Capture pictures at areas that least have movement caused by human interfernce or windy or suny blurs. Also, capture pictures maybe retored of blurry filming from computer photo video editor programs. Capture the picture or videos to be loaaded on to a computer that allows editting to achieve desired interfaces.
Feb 07, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Take pictures, reads unable to recognize files, and doesnt even show i have taken a picture
The camera may require manually opening the shoot lense to achieve flash to capture pictures. Observe the camera buttons for every complementary buttons that may require activation prior to photo shoots. Usually smaller cameras with lenses may require manual lense adjustments prior to every photo shoot.
Feb 03, 2011 | GE X5 Digital Camera
Samsung S760 digital camera.Lense does not not retract and there is no display on screen.Camera does not respond when any function button is pushed..Installed new batteries.Green indicator flashes when...
You may have gotten a light debris in the lens. Just the littlest amount will cause the lens to jam. Try a can of compressed air and blowing it out.
Jul 23, 2010 | Samsung S760 Digital Camera
My Camera is Canon 40D with EFS 17-85mm lense. I am having 2 problems,1.when I zoom the lense at 85 at 'AF' it doesn't get the focus, some times it get focus but picture got blurred.2 after capturing some...
Your flex cable to the Iris is broken. Have a look at my gallery at http://www.pbase.com/barry_2718/efs1785mm I have the same symptoms. At 28 or 35mm it make work ok. try Av mode and f8 aperture to see if you get an err01 because the aperture does not move either.
Jan 02, 2010 | Canon EOS 40D Digital Camera
I dropped my camera and now it takes blurry pictures!
broken, try to be more careful. this is an ALRIGHT SO-SO camera for leisure, not scratch resistant, if dropped, will malfunction.
Nov 14, 2009 | Samsung S760 Digital Camera
Stuck up lense of samsung s760
did you check if your battery is dead. When batteries are dead, your lens sometime get left out.
Aug 22, 2009 | Samsung S760 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Black screen
Could be something covering the lense or the lense is broken
Sep 29, 2008 | Kodak EasyShare DX4330 Digital Camera
IPhone camera
My camera opens the "lenses" but it is black. Also up-date to the newest software 2.2 does not help. Before, it also showed that no space is anym more and some pictures should be deleted. I did not have any photos in the camera. The camera was new.
Jun 20, 2008 | Apple iPhone Smartphone
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
