Question about Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in. Flat Panel LCD Monitor
Hello, recently my Xerox 19-inch LCD Monitor screen just went black. When I power it up the blue power light will be solid for approx. 5 secs and the screen will light up greyish-black, then the screen loses all light and the power LED flashes. I think it's a communication problem or something? I'm trying to remove the rear case to check the inside, but I actually can't figure out how to remove the case! I removed the base and took out two screws from the back of the unit, but don't know where to go from here. I notice 4 female screw ends into the rear center of the monitor, but I'm not sure if they're a part of the removal or not. Thanks for any help you can give me! Problem not resolved
Hey rg213 I had a similar problem with my screen over the past week. This is "solution" is annoying but has been 100% effective every time I wish to use the monitor.
After your computer has started to boot and the Xerox logo flashes continually, reach around to the back of the monitor where your power supply plugs in. Slowly, and carefully start to pull out the power cord from the monitor until the screen lights up a bright white. Let it sit there for approximately 4 seconds then completely unplug, and replug the power cord back into the screen.
I should note that when you're pulling out the plug from the back of the monitor the screen will not light up until the plug is about 3/4 of the way out of it's socket. You should also be very quick when plugging the cord back into the monitor. If you wait anymore than 5 seconds (In my experience) the monitor won't power on.
This leads me to believe that it's actually our power supplies that are going bad and that maybe by buying new ones it will completely resolve our issue. Alas, a new power supply is not in a college students budget. I hope my unorthodox solution works for you :)
Posted on Aug 26, 2009
I concur replacing the bulging 470uf's and 220uf's on the psu pcb does the trick, when your xa7-19i 's blue power led flashes intermittantly on powerup, you can imagine can't u the psu feedback circuit going u good? no! ok! u good? no! ok! etc
The caps in the output of a smpsu have to have a high ERS rating or something ie they are dealing with pulses of power and it wears them out :-) They get hot and sweat......
Posted on Jul 02, 2009
Yes the problem is in the capacitors, you need to replace all the 470uF, 220uF and the 100uF capacitors, unless you have a cap testers then test each and find the bad ones, 25v or 35v are fine.
Posted on Jun 22, 2009
What do you do after you open it up? anything to look for? how can the problem be fixed after opening up the monitor?
Posted on Jan 13, 2007
Just tore mine apart so here is some help. You need to remove the two screws on the back of the case on the bottom. Then you remove the front cover it slides toward the top of the screen then lifts off. You can pry it off if that doesn't work. If you want to seperate the screen from the back cover you then need to remove the swivel mount and the other two screws from the back cover.
Posted on Jan 04, 2007
3 Suggested Answers
SOURCE: Screen goes blank also.
The thing with removing the power from the back of the monitor and holding the Down Button down whilst plugging back in the power does work. My 19inch Monitor was having the same sort of problem. White lines would appear as I turned on the monitor. I did the hard reset on the monitor and it works! I was awed and amazed.
Posted on Nov 26, 2007
SOURCE: Xerox XG-91D 19 in
it look like you need an inverter
Posted on Feb 17, 2008
Movement of my desk caused the monitor (XG-91D) to lose some of the colors. The screen only displays greens, blue, brown, gray and black tones. Readjusting the screen temporarily helped but it goes out...
Try a new cable. If any of the pins is slightly bent the monitor will not receive the correct signal to display. I would recommend a new cable even if you don'y see anything wrong with the old one.
Dec 09, 2017 | Xerox XG-91D 19" LCD Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
My Xerox XG-91D has gone totally black. No leds light up when I plug it in. The power supply is separate from the monitor itself. The power supply led does light up when I plug it in so I know that it is...
This could be a back-light problem, it can be caused by a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty. The CCFL lamp is a mini fluro tube.
Check LCD Parts for service, parts, and DIY info - click on this link to their WEB site :-
www.lcdparts.net
Oct 25, 2009 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in. Flat... Problem
If you look on the back of the monitor it has the name of the manufacturer - which I googled and found this warranty information: http://www.sylvania-displays.com/Support/warranty.html
If you already know that your monitor is out of warranty but want to try to figure out what's wrong with it, these are the contact numbers:
California:
PTI
7373 Hunt Avenue
Garden Grove, Ca 92841
Phone: 714-799-3899
Fax: 714-379-6290
Hours: 8AM to 6PM Pacific Time
Texas:
PTI
10849 Kinghurst Suite # 120
Houston, TX 77099
(281) 530-4100
(281) 530-4104 fax
Hours: 8AM to 6PM Central Time
For further warranty information, please contact our Customer Service Department
Call our toll-free service number at 1-800-776 8439 for out-of-warranty service rates.
Jun 23, 2008 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in
Oct 11, 2007 | Xerox XG-91D 19" LCD Monitor
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
1,013 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
