Question about iLO (2 GB) MP3 Player
Mp3 player comes on then says "flash error! please back up the data and format the player"
I hold down the button to turn it on and the screen pops up with the flash error and i dont kno how to fix it,the directions wont tell me how to fix it ether then i cant turn it off.
    Problem Solver:
  • 8 Answers
HOLD THE POWER BUTTON AND THE LOCK BUTTON WITH PLAY BUTTON AND THE RIGHT BUTTON ON THE MP3PLAYER
Posted on Nov 06, 2008
Sandisk
Format and then firmware upgrade
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa m240 MP3 Player
Flash error please back up the data and format disk
Reformat the player.
If you have a Windows-based computer,
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
May 05, 2008 | MyMusix PD-6030 MP3 Player
Need help ?
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 22, 2008 | iLO (2 GB) MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
Format error
Hey.
Well first, some of the songs that you put in, well...Sony Co. cannot transfer directly, so you would have to use their Sonicstage program, aka the converting button.
Like most Sony mp3 players, you need to use Sonicstage to put songs in the mp3 player.
For the Sony NW-E405, simply go to the Transfer menu at the top right of the program, (along where the My Library button is) and select the song. In the middle of the screen should be arrows along with a suitcase looking button. Click the luggage button and a screen should pop out. It should have two choices, a Standard Transfer Mode and a Specified bit rate transfer mode. Click the Specified one and select either the 105kbps (ATRAC 3) or the 132kbps (ATRAC 3) for great sound quality and small memory usage. The others are too big or too bad for sound quality. It should now work.
Now the mp3 player should be able to read it, since it is now in ATRAC 3 version, not the mp3 version.
For the songs with no data, the songs are unquestionably banned from the Sonicstage program either because of illegal data in the mp3 songs or the corruption of the data itself. It happened to me quite a lot.
You could try converting it like the top section...some of those songs worked.
Hopefully this solution helped.
Have a nice day!
Nov 05, 2007 | Sony NW-E405 MP3 Player
Flash error - won't let me use player
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Oct 27, 2007 | MyMusix PD-6030 MP3 Player
Mp3 player has an error
My Musix MP3 when turned on says flash error please backup the data and format the player. When I put it in the computer no message to tell me how to do this comes up. I don't have the manual anymore. Please advise.
Oct 24, 2007 | MyMusix PD-6070 MP3 Player
Format
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Aug 01, 2007 | Philips GOGEAR SA6045 MP3 Player
Refresh Database
Format the player using the formating tools given in the disc-yr problem will be solved
Mar 08, 2007 | SanDisk Sansa e250 MP3 Player
Wont turn on
hi try charging it completly good luck
Apr 06, 2006 | Thomson Lyra PDP2840U MP3 Player
iLO (2 GB) MP3 Player Logo
78 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
