Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Washer Control Locked
The control panel is completely locked up. We've tried unplugging the power. How do we unlock the control panel?
  • RossIdaho Nov 05, 2008
    We finally found our original manual and found the solution. Someone had accidently pressed the End-of-Cycle Signal button for three seconds which locks the Control panel and puts a red light next to "Control Locked". This is used to keep a setting from being changed. Holding the EOC Signal button again for three seconds turns off the Control Locked indicator and gives you back control of the machine.
    Scholar:
  • 62 Answers
I need some more info.. when you say locked up do you have a dispay or is it blank?
Posted on Nov 04, 2008
  • Steven Haney Nov 05, 2008
    Thank you for your response, that was what I was gong to suggest but wasn't sure what you meant by "locked up". Happy washing!
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. You also cannot unplug the washer to reset it. The Control Lock can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked how do I unlock?
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It said contorls locked and will not work. I tried to unplug and reset no luck.. any suggestions please!!!!!
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our washer says control locked. i dont know how to
Unplug the washer, and leave unplugged for about 5-minutes. Re-plug and check. Hopefully this resets the controls.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked stays on
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are also included in the owner's manual.
If these steps do not provide you with a solution, you may have a more serious problem than a simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control is locked
Have you tried pushing and holding the End of Cycle Signal" button in for 3 seconds? This button is used to lock and unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the control panel near the button.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock on model ghw9100
Try pressing and holding the "End of Cycle Signal" button in for 3 seconds. This button is used to lock/unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the front panel near the button.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
