Question about Samsung SpinPoint SP6003H (SP-6003H) 60 GB Hard Drive
How to recover space
Dears, I had an old motherboard which allowed only 32GB to my HD SP. I have changed it for a new one, but despite the fact that the Bios recognizes now that the Samsung HD has a capacity of 60GB, there are still 25023 Mo which are not allowed and I don't know how to recover it. How can i get that space back? Thks in advance Emile EDINGUELE H
    Scholar:
  • 41 Answers
Older motherboards without large disk support only handle a partition size that it can manage. Depending on the motherboard, it either partitioned the drive and used a 32gb portion, or it just disreguards the span after the 32gb point. If the former is the case, you may have to repartition the drive. There are some programs that allow you to do whis without reinstalling your OS, but they have a risk of corrupting data. If you have the ability to backup all your computers information and reformat/reinstall your OS, things should be back in order. Warning: Make sure you educate yourself on the process before you set out on this job. You will want to backup any information on the drive as well as make sure you have any drivers you may need before you begin. (if you are using windows XP, I suggest you read up on this article: http://support.microsoft.com/kb/313348 ) If you want to attempt a repartition without reinstalling your operating system, you may want to try Partition Magic, Drive Image, Norton Ghost, or Partition Logic. (Some are free, some are not. A quick search will help you find their websites for more info.)
Posted on Nov 20, 2006
SOURCE:
I received an 11.5 galileo Pro for Christmas and it already has 80% memory used. Do I do a hard reset? Or is there another way to get rid of the memory?
You don't want to 'get rid or memory', you need to regain memory.
The tablet only has 32GB of memory and some of that memory is used for the operating system. My iPhone has 128GB memory and despite having 4,000 images and 120 Apps, I have 80% free. You need to work out what you have that is using lots of memory space. Apps like Google Earth are huge. Videos and Films take up space. Yes you can do a Hard Reset, but it will delete everything you have on it and reload the operating system clean.
Not bad specs for an $80 tablet APART from the lack of memory!
RCA Galileo Pro 11 5 32GB 2 in 1 Tablet with Keyboard Case Android 6 0...
Jan 03, 2018 | The Computers & Internet
No image computer after BIOS update
try to get the old bios and put it again
Feb 05, 2018 | Intel Motherboard
How to reformat a laptop using the F9 function?
So my questions would be are you attempting to restore your PC to factory settings? or put a new Operating System on it?
If you are trying to restore to the way you got it, you probably have a recovery partition on your hard drive. If this is the case you are going to want to restore to your recovery hard drive.
If you are trying to put a new operating system on your PC then you will probably want to recover to the non recovery hard drive.
The other option to use the entire hard drive will give you more space on your PC to use, but will wipe out your recovery partition. Hope this helps.
If this isn't making sense try taking a picture of your partitions and posting up here so we can give you better advice.
Oct 28, 2012 | Computers & Internet
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
My Lacie external drive clicks but won't spin up. It is about a year old, maybe less. It was working fine and just stopped working. It has not been dropped. In fact it hasn't been moved.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Jan 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I replaced my hard drive with a new Hitachi 500 GB and it only reconizes 32 GB.
What format did you use? it must be at least FAT32 to recognize more than 32Gb.
Check BIOS settings too.
Sep 17, 2009 | Dell Dimension 2400 PC Desktop
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
Abit motherboard problem/HD
Hi coonster,
Actually you can do more. If you haven't updated windows please do so! Once windows SP2 has been fully updated & running correctly use windows disk management utility.
To load windows utility click the start button & type diskmgmt.msc in the run windows, click ok.
Windows may have added another drive letter to your drive because of the 137GB block. Use disk management to delete any added drive letter. Window disk management can add the additional space to your C: drive. If windows still gives you a hard time I suggest you download partition magic 8.0 or 8.1 from this site. (Its free). Install partition magic & use it to regain all your of the drives data space.
http://www.click-now.net/downloads09.htm
Mike
Nov 17, 2008 | Abit : KV7 Socket A KT600 Motherboard
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Trying to boot from a hd from my old comp
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Jan 13, 2008 | Computers & Internet
Samsung SpinPoint SP6003H (SP-6003H) 60 GB Hard Drive Logo
381 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
