Question about Dell OptiPlex GX260 PC Desktop
Bios chip mother board - Dell OptiPlex GX260 PC Desktop
    Genius:
  • 1,689 Answers
What do you need from the bios chip motherboard?
well if in case you will need some info about it just go for the documentation from dell found in the link below...
http://support.dell.com/support/edocs/systems/opgx260/
Posted on Nov 04, 2008
American Megatrends Inc. E1762II1.30O 2012-08-15 Bios Mode: legacy Laptop CZ-17 Valkyrie IBP Attempting to turn off integrated graphics card, cannot due to zero BIOS options beyond boot-order.
talk with a computer repair shop
The bios is a program in the computer chip and can be changed within set parameters as listed on the bios pages
if you want the latest bios applications you may have to get a new chip and as chips and motherboards are constantly changing you may need a new mother board for the latest chip
Dec 18, 2016 | Computers & Internet
Bios chip location on dell latitude e6400 mother board
Hello Gideon,
That is how the bios chip looks like.8 legged chip.hope that helps.
May 13, 2014 | Dell Latitude E6400 Laptop
I have a desktop with an amer megatrend bios.I want to get a new bios that works with win 8.1 and needs to have support for PAE,NX.and SSE2
It's best to simply replace the entire Mother Board than try to replace the BIOS. Replacing a Mother Board vs replacing a BIOS is way easier.
Your current BIOS MIGHT work if you can find a flash file for it, but you have to be careful. If the BIOS your flashing isn't in production it's usually only PATCH flash file, to fix a problem with a BIOS, not upgrade it. And if you use the wrong flash file, it will TRASH your BIOS!
The BIOS, which is a chip, is usually micro-soldered to the Mother Board with high precision, by a robotic arm, and not easily removed or duplicated. The exception is if you happen to have a BIOS chip, that can be replaced, in a socket, but this is unusual instead of common.
The best source for BIOS info such as you are looking for is the American Megatrends Website itself at: AMI American Megatrends Inc Aptio (compatible with Windows 8) however their website is for the Mother Board manufacturer so you can't buy the BIOS as a consumer, but through a reseller, AMI Office, Authorized Representatives, etc (AMI American Megatrends Inc How to Buy).
You can however, buy a replacement Mother Board with a BIOS already installed on it (that's the way you usually buy them - with the BIOS pre-installed on the Mother Board) that's PAE, NX, and SSE2 and whatever else you want compatible. A great website to find computer parts and kits, new, refurbished, out of box, etc is the Tiger Direct Website at: TigerDirect com Electronics Tablets Phones Office Supplies Video Games. Just search for BIOS to find your specs, then check the bottom for possible best Mother Board kits to replace the one you have now. Hope this helps. :-)
Mar 03, 2014 | Computers & Internet
I need to change my bios chip for compaq presario f700 but i can't fin it in the mother board does some one knows where is it ? in the main board? exact place please
Changing the bios chips on that particular logic board requires soldering. It's a black chip with white writing on it, it's flat, and it has about 20 prongs on it.
Mar 22, 2011 | HP Compaq Presario F500 F700 and G6000...
My chipset motherboard P25G, bios can't start.Cant even go to the bios setup menu?just the power led turn on and died again..the power suplay is good.thx..
make sure metal tower is firmely tight on the black chip on mother board with braket tightley clamed on it.and also check fan make sure thats tight on mother board.
Feb 18, 2011 | PC Chips P25G Motherboard
I have intel chipset mohterbord. i press start button.the smps fan running but mother bord led is not glow. no signal are find monitor pls help me.
Please remove the CMOS battery.Hold the power switch and fit the cmos battery . And go to set up BIOS,and set the bios fail save default.
Follow link.http://www.pcbuyerbeware.co.uk/BIOS.htm
If the problem is same Change the DDR1 RAM from ram slot from any running pc or new if you have a spare.
OPEN the BIOS chip using any thin pin and fit again tightly.
Follow link http://dexplor.com/phpBB2/viewtopic.php?t=7747553
You can change the SMPS or use it in another pc for test ,again the problem is same please change the MOTHER BOARD.
REGARD's
SHIBUDA
Jan 05, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Motherboard crash bios
1st remove ur mother board battery and clear cmos and press reset when machine start then shut down and change a new battery and fixd cmos. i hope ur problem will solv
Mar 17, 2009 | Computers & Internet
Pc starting problem
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Mar 10, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
865 mother board sound driver
The fact that the driver is not being prompted or autoloaded by the OS tells me you might have to enter the BIOS and enable the sound features. Sometimes they are off by default. I would also look for an updated BIOS while I was at ASROCK the real maker of your board.
try this site
Jan 04, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Aug 20, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Dell OptiPlex GX260 PC Desktop Logo
70 people viewed this question
Alun Cox
