Question about Pioneer DVR-633H-S
TV Guide reset
I read the previous posting about the TV Guide feature resetting itself. In my instance, I keep receiving the following message: "Updated information will be available within 24 hours. The Guide is rebuidling your channel list based on your setup change." The problem is that I haven't made any changes, and it never does reset and display properly. Any thoughts?
Try this (with the original remote): Reset TV Guide On Screen
1. Press the TV Guide button
2. Curser up and over to the SETUP menu
3. Select Change system settings (highlight only)
4. Enter the following numbers … 753159852 (setup mode)
5. Enter the following numbers … 653274147 (reset mode)
It will take some time to get the guide downloaded, but it works.
Posted on Nov 13, 2008
  • angels_payso
    angels_payso Jun 07, 2012
    not sure if I'm suppose to go to the tvgos after the wait a moment goes away? so at the moment I'm just waiting before going to the tv guide. Can you tell me what to do after step 5. Thanks, Peg
  • angels_payso
    can you tell me what I do after step 5. do I just wait an hour or 24 hrs.? what happens after I enter the numbers in step 5 is that is say wait a moment then it just goes right on playing whatever is on tv. it doesnt go to the tvguide.
Freesat box keeps freezing when you put TV guide on
Go into Factory reset, but before check if your system download is up to date, ( in menu )
Aug 10, 2014 | Humax Televison & Video
On y tv the light at the front keeps flashing red and green. what is the problem?
It may be in the safety shutdown/restart mode because it may have bad power or it detects shorted circuits. You can try unplugging it for about an hour to let it reset itself first, otherwise you will have to troubleshoot it if it does not reset.
Please read my guide first before DYI.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Jan 13, 2011 | Hitachi 32LD8700 32 in. LCD Television
I have direct tv dvr my remote wont work,but remote works on my other recivers,has the ir gone bad and can it be fixed
It's possible that the IR receiver in the DVR has failed. It's unlikely to be the remote as it works with other devices. If the remote was working with the DVR before, then in most cases the problem can be corrected by resetting the DVR as follows:
Press the RED RESET BUTTON behind the access card panel on the front of the DVR. Wait for the program guide information to update then try the remote again.
Try this and post back if you need further assistance.
Regards,
BElectric
Dec 07, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
Retrieve a message
Depending on what VM system you have there is a feature # you key in.
For instance the Nortel Callpilot feature is "feature, 981" If this is your first time logging in you will have to enter a password. Contact your systems administrator to reset or set your password to never ask.
Aug 22, 2008 | Nortel Meridian M7208 Corded Phone
Warning message
try resetting the machine by pressing the features button and then in fast sequence 2,8,6,4, if you do it right it should flash test mode, then enter 91, and after you do this enter 99 to get out of the test mode
Feb 23, 2008 | Brother IntelliFax-2820 Laser Fax
Clicking noise sony bravia kdl-40v3000
Normal 0 My kdl-46v4100 has been off all day and I've heard two or three clicks. It sounds exactly like the click you hear when it’s been off all day and you go to turn it on. A few minuets after it clicked I turned it on and to my surprise there was NO click sound.
This LCD TV (like most large displays) uses an Active Matrix of thin film transistors, aka TFT. Essentially the screen is a large array of transistors and capacitors. According to my previous observations; I suspect the random clicks are associated with the LCD circuitry providing a fresh “standby charge” to the TFT array (hence no click on power on following a “refresh”).
Not a solution, but an explanation other than “cooling off…”
Nov 29, 2007 | Televison & Video
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
TV GUIDE
Sometimes this can be cause by a intermittant power strip or extension cord.. Check it out and please report back?.
Oct 05, 2006 | Pioneer DVR-633H-S
Pioneer DVR-633H-S Logo
952 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
