Question about Metz 60CT-1 Flash
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
I read a similar post but my flash still has issues. My Problem I have been using a Metz 60-4 flash with dryfit battery for a few years and recently began having a problem. With the flash set on TTL the flash takes much longer than normal for the ready light to come on to allow me to take another photo. I replaced the SCA 3000C and SCA 3402 modules/adapters on camera (Nikon F100 and Nikon N90) and also purchased a MZ 5320 replacement battery.My next step is to send it to Metz but I was hoping there was something simple I overlooked. Any suggestions?
The battery itself may be packing up. Try borrowing a good one and see if this solves the problem. Next try to replace the capacitor in the battery pack. Also do you know of a decent wide angle diffuser for the Metz 60 ct 4. Regards
Tmgb
Posted on Aug 19, 2008
    Champion:
    Scholar:
  • 216 Answers
If I can help.
atdlee@netzero.com
Posted on Feb 19, 2008
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Posted on Apr 11, 2007
SOURCE:
My Metz 58 AF-2 isn't working, it still has all the lights and beeps but isn't flashing when you take the photo. I think it's the bulb but not sure on how I change this or if I can do it myself?
When you trigger a flash can you hear a high pitched sound (charging oscillator) or is muted? Are the batteries fresh? If indeed the discharge element is defective it needs to go in for repair or replace it.
Mar 27, 2014 | Metz Cameras
Metz 44AF-4C ready light does not come on,has new batteries, all functions work?
The energy for the very short, very high brightness flash is held in the flash capacitor of the photo flash lamp. This capacitor degrades if is not charged for long (years), and needs formatting, which is a slow charging and 2-3 consecutive shots. Sometime the first charging takes significantly longer than normal time, even minutes. If however the ready lamp does not come up even after some minutes, the flash lamp may have developed an internal fault, which can only fixed by a trained repairman. Another common culprit is wrong contact in the battery compartment. Batteries left in the flash for long often leak, and corrode the contact springs and leaves. These can be cleaned with soaked with vinegar cotton tabs (ear cleaning buds), followed by mechanical cleaning with pencil eraser.
Feb 24, 2014 | Metz Cameras
METZ 60 CT-4 batteries and capacitors
Although you can still get lead acid batteries from Sonnenschein (the original oem manufacturer) for the Metz CT60 units, a better choice are the Lithium ferrite phosphate or Lithium ion batteries, now available on ebay. For example sales8phd on ebay sells a drop in replacement 6 or 7Ah battery with a charger for ~$75. In general these batteries produce more flashes per charge than the lead acid oem batteries,particularly when shooting a lot of flashes in rapid sucession.
Jun 01, 2010 | Metz Mecablitz 60CT4 TTL Flash
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
How can I match Metz 45 CL-1 with Nikon D-80
Try to keep the Flash setting on ISO-setting of 100 constant and adjust your aperture setting on the flash..Do not try to sync with the camera settings..it will normally work...for example.if your camera setting is as this: ISO-400, shutter speed is 125 and aperture is F8, then keep the flash setting as i mentioned above.this setting in an evening environment in a hotel or party event. this may help...
Aug 25, 2009 | Metz 45 CL-1 Flash
How can I match Metz CL-1 with Nikon D-80
you can buy a metz module to make them compatible.around 30 pounds price tag.
Aug 24, 2009 | Metz Mecablitz 60CT4 TTL Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Flash and Shutter not in synch
Good Day, flash assy is defective, the light sensor that will detect the correct flash exposure is defective, no longer user serviceable, contact nearest svc ctr for replacement of flash assy. thanks
Nov 19, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Metz 60CT-1 Flash Logo
615 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
