Suddenly no power with dvd player. no tv trouble and no power trouble. If its a dead power supply, how do I get my disc out? thx
    Sergeant:
    Novelist:
  • 196 Answers
You can just open the dvd by removing the screws .its very simple.the front cover will come out once you remove the screws, and the dvd disk will be visible gently without damaging the lens take out the disk.
thanks.
Posted on Nov 05, 2008
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
DVD player has no power.. just had a new tv installed and dvd appears dead
Dear Sir, 1.Check Power supply outlets and Cables.Then switch on front panel on/off button.I think it helps Let me know.
Jan 09, 2011 | Panasonic DVD-S325 DVD Player
MY TV/DVD PLAYER will not turn on. The ready
that might not be totally dead if you will have the power supply checked by a qualified technician
Aug 16, 2009 | Televison & Video
Stopped working halfway through playing a disc .absolutely dead now no display
if the unit is absolutley dead, nothing no go what so ever, my advice is check out the power supply.
Jul 06, 2009 | Cyberhome DVR 1600 DVD Recorder
Loud hissing from speakers
it could be the lead, so try replacing that it is highly unlikely that it is the tv so i would take the DVD player back to the store.
Sep 05, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Remote stopped working
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
Feb 09, 2008 | Televison & Video
Diamond vision DVD player powers off when dvd is inserted.
your set needs the tech doctor you are having a problem in the power supply with your regulator or diode in the power supply.
Mar 05, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
