Question about RCA RP5430 Clock Radio
Can't change clock to eastern standard time
This particular clock (RCA RP5430 Clock Radio) automatically sets the time.  It does not have a manual intervention.  I have read the instruction manual; taken the batteries out and put back in hoping that would reset the time; moved the daylight savings time switch back and forth and still it's the wrong time, since the time changed last weekend.  For example, it's now 6:14 p.m.; the clock says 7:14 p.m., and if I move the daylight savings time switch it says 8:14 p.m.  any ideas?  thanks,  Dorothy
  • 1 more comment
  • Anonymous Nov 10, 2008
    GET EXCITED ABOUT THE TIME THRU OUT THE DAY TO DISCOVER I HAVE LOST THE SAME DUMB HOUR AGAIN
  • Anonymous Apr 08, 2009
    I just bought the same clock and it wont find my eastern time! Two months ago I bough a rca radio clock RP5505 and it doesn't work. Now bought this one and it doesn't work. NO MORE RCA!
  • Anonymous May 16, 2009
    I can not set the time on the clock.
You can change the time zone. Push the time zone button until the correct time is displayed.
Posted on Aug 05, 2009
Can't solve it but the clock doesn't know the government changed when daylight ends.
Posted on Nov 09, 2008
How do you set the alarm and clock?
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Setting Wake Time
This unit allows two wake times to be set.
on the top of the unit to WAKE 1 or
WAKE 2 position.
respective wake time. The time
decrements or increments will follow
by a faster rate when you press and
you are setting the time.
when finished.
http://audiovox2.info/docs/common/RP5430/RP5430_OM.pdf
Mar 15, 2011 | RCA RP5430 Clock Radio
How do i change the time
On the link below is the manual for the radio.
http://www.voxxsupport.com/images/manuals/RP5430/media/RP5430_UMEN.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 07, 2010 | RCA RP5430 Clock Radio
Clock is flashing continuously and unable to set it.
Found the manual for this product here:
Looks like this clock has internal batteries that need replacing every 2-3 yrs.(See "auto-clock set" under "clock".
Hope this helps.
Dec 16, 2009 | RCA RP5430 Clock Radio
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Set time
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
Feb 17, 2008 | RCA RP5430 Clock Radio
Rp5430 clock radio aut time set not working
Dec 25, 2007 | RCA RP5430 Clock Radio
RCA RP5430 Clock Radio Logo
620 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
