Question about Apple iPod nano
Frozen and Corrupted
Plugged it in and nothing happens. It is stuck on hold so i left it plugged over night and the restore function had an error and im trying to use my warranty to get a new one. This whole Ipod thing fuckin sucks and they need to figure out their issues fast!
  • 342 Answers
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on
if that does not work you can view free iPod repair videos @: http://fixyouripod.weebly.com/
Posted on May 19, 2009
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
1st generation phone is frozen on apple screen, then if it goes off, it returns with a plug and lightning bolt with red in the battery, when I plug it in it goes back to the apple sign and stays frozen
Your phone is either corrupted or the battery was just drained. Plug iphone to pc, restart computer while iphone is plugged. Or What you have to do is to enter dfu mode so iTunes can detect an iPhone in recovery mode and then prompt you to restore. You will lose all your files when you do this but if you have a backup in iTunes then you're good to go. To enter dfu mode, just press both power and home buttons simultaneously for exactly 10 seconds. After 10 seconds, release the power but keep holding home then wait until iTunes detects your iphone and prompt you to restore.
Nov 28, 2011 | Apple iPhone Smartphone
My ipod is frozen
Warning: This should be used as a last resort, restoring will erase all of your data
*Must have iPod plugged into computer while doing this*
Be patient, the force restore part may take up to 20 seconds.
1. Press and hold the home button and the sleep/wake button. (the power off option will appear, ignore it)
2. When the apple logo appears let go of the sleep/wake button (keep holding the home button.)
3. After a few seconds you should see the connect to iTunes image (you can now let go of the home button.)
4. Open iTunes .
5. iTunes should automatically recognize your iPod once the image comes up, if not unplug your iPod and plug it back in.
6. Restore your iPod by clicking the "Restore" button.
If iTunes comes up with an error you may want to try
a. Uninstalling and reinstalling iTunes or
b. restoring on a different compute
May 26, 2009 | Apple iPod touch
Freezes on 'Samsung' screen
While the unit is connected to the PC, hold down the RESET hole at the back for 10 seconds.
Mar 23, 2009 | Samsung YP-Z5FA MP3 Player
I was working out with my Sansa e260 mp3 player, when it just turned off. I charged the battery last night, so it can't be that. When I plugged it into my computer, nothing happened. Do you know what's...
There could be a slight problem of it being frozen so try holding down the off button for 10 or 20 seconds and hopefully it will turn off or on that could be the problem or maybe not.
Dec 11, 2008 | SanDisk Sansa e260 MP3 Player
Only works when adapter's plugged in.
try plugging and unplugging the charger/ac adapter several times to see if the switch that is built into the jack might be stuck from dirt or corrosion.sometimes you can take a toothpick and get them unstuck too.
Sep 25, 2008 | Icom IC-R5 Handheld Scanner
My ipod nano wont do anything
By pressing the center button and the menu button the same time and holding it for around 6-10 seconds, your device should turn on. You then should be able to access your files and charge your ipod.
May 14, 2008 | Apple iPod nano
Ipod Touch Freezes
What You have to do is hold the top button and the power button at same time for more than 25 second this will lead to recovery mode, on recovery mode you connect to your pc and then restore it , if is taking longer to get into recovery mode plug it in the power adapter and then put in recovery mode. once you have it restore it.
This happen to me, it got stuck on the apple screen and it was restarting on and off and i could connect it because it recognize it when it turn on and few a second later it turn off.
so just put it in recovery mode first and then restore it.
Feb 28, 2008 | Apple iPod touch
Frozen ipod nano 3rd gen.
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Feb 04, 2008 | Apple iPod nano 3rd Generation
Ipod nano 8GB 3rd generation FROZEN!
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 26, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
61 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
