Question about NAD C370 2-Channel Amplifier
Nad C370 Hi, I have a NAD C370 that goes into protection after around 30 mins, sometimes more or less depending if the volume is higher or lower. I found this article... http://www.pithed.org/2007/10/12/nad-c370-protection-circuit-repair-amp-fails-goes-into-protection-mode/# these are the same symptoms as mine. I have changed the 3 capacitors nearest to the diode on the protection circuit as suggested on there. I also moved the diode to opposite side of the board as suggested, in the hope that it wouldn't happen again. However, the amp will stay on for a bit longer, it still has the same problem. Do you have any ideas about what could potentially be causing the problem? Do you think it is still a problem with the protection circuit? Any help or pointers you could give me would be greatly appreciated. Kindest regards, Gareth
  • 4,234 Answers
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Posted on Nov 05, 2008
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Losing one channel, comes back if you move the volume switch around then goes again ?
That must be a dirty volume control (potmeter).
Or there's a lose contact on the PCB which is soldered to your volume control (potmeter).
regards,
Gerard
Mar 22, 2010 | NAD C370 2-Channel Amplifier
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Knob for NAD amp?
Hi...
try your "local" NAD seller and ask them?
Contact NAD by email.
or
www.audiokarma.org
100's of users someone there should be able to help.
Jan 11, 2009 | NAD C370 2-Channel Amplifier
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
HELP PLEASE. NAD 370 JUST DIED...
This could be as simple as a bad connection at the voltage regulator IC or blown output transistors. If you have a multimeter and some experience with electronics repair, this should be fairly straightforward.
Let me know and I'll try to walk you throught the repair.
Dan
Sep 07, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD C370 in protection mode
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Feb 10, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
562 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
