I bought a Dell inspiron - 1526 computer. It says my Lexmark P4350 printer is compatible. It shows it is installed with the driver on my hard drive. I can't get it to show up when I need to choose a printer when I want to print.
  • 3,940 Answers
First go to control panel, and see if you can print a test page from the printers list (Right click the printer, properties, print test page button)
If you can't print a self-test, the disconnect the printer, uninstall the drivers, reboot, download the latest driver from support.lexmark.com, connect printer when prompted during drive install.
If you can print a self-test, then right click the printer icon, and click set as default, then reopen you application and try printing again
Posted on Nov 05, 2008
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
How to convert desktop hard drive to external hard drive?
See this... http://voices.yahoo.com/converting-old-computer-hard-drive-into-external-1481521.html
Jul 13, 2014 | Computers & Internet
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
Speakers don t work
try checking windows control panal too see if you have drivers installed. if o.k. try sound icon to see if you have ticked mute box. here's the one that got me,the dvd playing program had the mute box ticked. re-launch dvd played/media played and un-tick. good luck
Nov 10, 2013 | Computers & Internet
I have an imac computer model M6498EMC that is without a hard drive.I have all kinds of sata and ide drives.can i install one of these and how do i do it exactly
You will find at the bach of the PC there are little 'doors' with screwed covers. find an empty slot slide drive in and screw down then connect up inside to the loom on a spare socket
Sep 27, 2013 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
Www.hp.com/go/techcenter/startup
My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
System temperature (90D)
Apr 08, 2012 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
