Question about Gateway FPD1530 15" Flat Panel LCD Monitor
LG flatron L1718s monitor switches on for a split second then goes off. Cycling the power on/off gives a repeat of the above. Any pointers to where the problem may lie? I only have access to basic tools ie soldering iron, screwdrivers, multi-meter, no o'scope available. Any suggestions or help greatly appreciated
  • dominic_b Nov 05, 2008
    Thanks for the info, however, I should have been clearer in my original posting. I have tried the monitor on several machines, it was originally connected to my windows 2003 server, I checked it on my laptop as an additional external monitor and it gives the exact same problem. The server room that it has been sitting in for the last 3 years runs hot (approx 84degs F) so it may be a dry joint somewhere (i've been looking at posts elsewhere). However, I spent 5 mins last night just trying to work out how to get the back cover off and couldn't work it out :( It may be that I was too tired to see the obvious, but there were definetly no screws to take out......
  • onest-tone Nov 25, 2008
    I have exactly the same problem with an LG Flatron L1715S. I have carried out the appropriate lead and monitor substitution tests to confirm it is a not a lead or vga out problem so it has to be the monitor. The monitor is about 4 years old and not exhibited any problems before. It has been picked up and moved but not handled roughly.
    Scholar:
  • 53 Answers
Check that the monitor is indeed the problem, plug the montior into a different pc or laptop and see if it works.
if so then borrow a monitor from somewhere plug it in to your pc and see what happens if it does not produce a picture then check that your graphics card is seated correctly in your motherboard.
also this is where it gets tricky, but if the graphics card is AGP make sure that your bios is set to use the AGP (not PCI) as it's primary or vice versa if it's a PCI graphics card.
(I say tricky because you may not be able to view anything if you don't have or can't borrow a different type of graphics card ie try a PCI one if you have AGP) to do this step you will need to install a spare card.
if you still have no joy but you get the monitor to display something when it is plugged into the different PC, at least you know the monitor is not at fault.
Posted on Nov 04, 2008
How to open a FLATRON L1718S LCD screen
Those screens are so inexpensive, it really isn't worth your time to try to repair them...Spend a buck and use your time for more important things!
Dec 14, 2012 | LG Flatron L1710S 17" LCD Monitor
My monitor goes for 3 seconds black, every 1 minute
First thing, try to connect the monitor to another CPU and see if its gonna work. If it doesn't, then this might be a capacitor failure. One of the capacitors in your monitor that are responsible for holding up power for proper display is faulty. A faulty capacitor is either bulged(with a hump head) or burst. This causes the monitor to go off a few seconds after you switch it on because the capacitors can no longer hold power long enough for your display. One way to work this around is to take your monitor to a Computer Technician to open it up and probably replace the faulty capacitors
Nov 06, 2011 | LG Flatron L1718S LCD Monitor
Having a LG Flatron L1718S. In the last week, when I start the monitor it shows about 1 second the image of the computer, the it turns black. Same appears when I disconnect it from the computer - a...
That means the monitor has a problem with the Capacitors. Capacitors inside your monitor can no longer hold up power long enough for your display. This is so because the capacitors might have been blown. This makes the monitor to go on for about 2 to 3 seconds then it goes off.
The solution is to change the capacitors from the board (the part that you connect he power cable). This must be done by a Computer Technician who will safely carry out the procedure. Open up the monitor, using a flat blade and try to separate the cover with the LCD, starting from the bottom, working your way through around. Before you do anything, check for any burged or any with a black smoked colour capacitors...If you find any, then it has to be replaced
Aug 22, 2011 | LG Flatron L1718S LCD Monitor
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
Feb 10, 2011 | LG Flatron L1718S LCD Monitor
LG L1718S monitor comes on then goes blank in a second. Please help
This a power failure normally caused by a capacitor failure. Capacitors in this case might be leaking, barged (instead of a flat head, the capacitor has a barged top). When you switch on the monotr, the capacitors are supposed to hold the power enough for the proper display on the monitor. In your case the capacitor(s) are malfunctioned.That is why they can not hold power for more than 5 seconds
Solution:
Get a sharp and flat tool and open the monitor (starting from the bottom) working your way round to the top. You will notice finger-like clips that hold the covers together. Once you have opened it, check on the electronic board where you connect the power cable. Notice any barged-head capacitor, or leaking capacitor(s). If you find any, they have to be replaced. Get a Technician to do this for you if you can not.
Jan 16, 2011 | LG Flatron L1718S LCD Monitor
When i turn my computer on the monitor flickers for a second then just goes black. at the start i can see the desktop but after that it goes black lg flatron l1718s
You may have problem in the power supply, common causes are the bad capacitors (bulging top/seal, or leaking). That will be the first place to check. I will assume that you have already try it with another PC and it still does not work. See pictures here for a guide so you know what to look for inside:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find so it will help out other people also.
Apr 06, 2010 | LG Flatron L1718S LCD Monitor
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
436 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
