Parallel shadows across the screen
There is less contrast, and there are parallel shadows across the screen.
  • eloise44 Nov 07, 2008
    We found out that it was not a problem with the monitor, but a computer problem. We hooked up the monitor to the laptop and it worked just fine.
Hi, what type of the monitor, LCDs or CRTs???? Also, will the shadows being shown at the same spots or at different spots at different time?? it could help to narrow the problem, post it on more detail if possible.
Posted on Nov 05, 2008
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
Connect batteries in parallel
Parallel battery connection means that no anode and cathode (no + and - ) terminals are ever connected together. Each battery will be connected positive to positive and negative to negative to the next battery, and so on until you reach the battery that is connected across the load.
Important to remember: Connecting batteries in parallel does not increase EMF (voltage), only capacity (the the run time prior to full discharge). Batteries connected in series does increase voltage ouput, in the same manner that battery cells increase batteru voltage ouput by adding together the voltage out put of all cells in the battery.
Jun 08, 2012 | Minn Kota Edge 40 Freshwater Bow Mount...
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Why must voltmeter be connected in parallel w/ circuit component
When connected in parallel it reads the voltage drop across said component.
When connected in series the current flows thru the meter allowing the measurement of the current flowing thru circuit.
Hope that helps.
Jan 04, 2009 | Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery...
Where to connect on computer
The printer will have one of two cables , either it is a USB cable , or an LPT cable
USB Cable Looks Like This:
The LPT Cable Looks Like This:
If it is the USB cable , it will connect to the back of your computer in a USB port, which looks like this:
It it is the LPT cable , it will connect to the back of your computer also:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Aficio 2022 connected to computer by parallel port
Hey Bubbabear,
I've got a Rico Aficio 2035
1.) It does have a hard drive installed (doc server)
2.) There is not a memory card installed
3.) There are no pinter buttons on the control panel
The rest of the scenario is the same...IE1284 Parallel port, but does nothing...
May 15, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
May 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Computers & Internet Logo
703 people viewed this question
David Payne
David Payne
