Question about Panasonic TH-42PWD5UY 42 in. Television
WHAT DO I NEED TO CONNECT A PS2 TO MY TH-42PW5? (PLASMA) please help!!
I HAVE A PS2 And the original scart cable (RFU) that i used to connect my old tv to the console. Im trying to connect to the plasma but im not very technical. do i need more than this. someone please help
5 Suggested Answers
  • 86 Answers
SOURCE: game console and plasma displays
You did not list which console you have and what type of cables it has.
Looks like your plasma has:
1 component
1 composite
1 VGA
1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work:
http://tinyurl.com/3aoev9
here is the ebay search i used:
http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
Posted on Feb 14, 2008
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
Posted on Jul 01, 2008
ripleymojica
  • 643 Answers
SOURCE: broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
Posted on Jun 03, 2009
Warf135
  • 137 Answers
SOURCE: We have a panasonic 42 inch plasma, less than 3
Try changing the video output mode of the playstation and dvd player from CVBS (often called composite or video) to RGB. this should sort the problem.
Posted on Oct 06, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
Bought a Panasonic plasma tv. Th-42PW5. Had to run thru VCR due to lack of connections available. Picture is entirely green. What can I do?
sounds like the cable or connections are not good. Your not getting all the signals or the tv needs adjustment/recalibration (if it is good).
does it have a test or demo mode to see if it is good?
some possibly useful links:
. Google
Mar 25, 2017 | Panasonic Televison & Video
I purchased a used Panasonic Plasma TV TH-42Pw5. I finally got a picture by hooking it up through a vcr, but the color is completely green. When using the remote instruction colors are varied. HELP!
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
I need a replacement tuner box for panasonic th-42pw5 plasma panel.can you help
It is Still Available with Some Vendors. You could Purchase it from :-
http://www.digitaldirect.co.uk/panasonic/tu-pta600b.html?referredby=WINDOW
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1421
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 08, 2010 | Panasonic TH-42PWD5UY 42 in. Television
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
How do you connect a toshiba dvd to a tlc plasma tv
First of all unplug tv and tosh dvd.
1.connect the antenna(digital aerial) to the ATENNA IN jack of the dvd.
2.connect the ANTENNA OUT jack of the dvd to the Aerial jack of your TV.Using a RF cable(usually supplied if new)
3.Connect AV1(TV) scart socket of the dvd to the scart socket of your tv.Using a scart cable.
Then you are ready to start and program the channels.
Oct 10, 2009 | Televison & Video
Trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Dec 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Trying to connect nintendo wii to philips matchline tv. the model no is : 42FD9944/01S
Whaere is the scart lead?
http://www.e-daewoo.com/products/owners_manual/DTS42(English).pdf
Please have a look at the above user manual from the Daewoo site. You may need to down load the Adobe PDF reader if you can't open the file. You can get that from this web site;-
http://www.adobe.com/products/acrobat/readstep2.html
I am not sure that this is exactly your model but one page of the PDF document , page 14 shows the connections at the back of the TV with no obvious SCART connection. So I think you will have to connect the two using a component video cable and the Left and right audio cables as show in the manual on page 28. or via an s video cable and right and left audio cables as show on page 30.
If the connections in this manual look about right for the connections on the back of the your TV set I would be tempted to take this manual printed out (or just the image of the back of the set page 14) down to your local TV shop with the Freeview box and ask them what cables they recommend you use to connect the set.
Also be aware that cables from these TV shops cost a fortune and you can probably buy the cables cheaper on eBay once you know which ones you need. Without seeing the freview box its hard to know what cable options that box offers you.
Regards
Aug 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
How to connect my COmponents to my new LCD TV
Do you mean a Playstation 2? If so, buy a SCART to component converter (like a SCART plug but with yellow white and red inputs) Put it in one of the SCART sockets and plug in your PS2. Hope that helps...
Jan 27, 2008 | LG 42LC2D 42 in. LCD HDTV
Panasonic TH-42PWD5UY 42 in. Television Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
