Question about Sony Playstation 3 (PS3) Console
PS3 will not work, it won't do nothing, It will not connect to internet neither!!!
I have a green light when power up, a green and blue light when I load it.
The only thing I see on the screen in 480P I think I should be 1080p, If
There's anyone out there thank can help me out or tell me its junk, What
ever, I sure would appricate it, Thank alot, Ronnie B. {Oh Ya, I was just
playing it 2 hours previously.}
  • Anonymous Nov 05, 2008
    I turn the power on, light goes from red to green & stays steady green....PS3 won't do anything...
    Problem Solver:
  • 5 Answers
If you hold the power button (about 5-10seconds) when turning it on. It will automatically set what resolution you would be able to view on your TV monitor.
Posted on Nov 05, 2008
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried...
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
Feb 06, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Cant get internet connestion
Are you hard wiring it? if so you may need to reboot your modem then start the ps3 back up. Don't unplug from the computer and connect it directly to your PS3 because the modem still has the computer's ip address and it won't recognize the PS3 until you reboot it. If it's a wireless connection, check to see that when you scan for wireless connection that the green wireless LED is blinking, meaning it's searching for a signal. If it's blinking, then try resetting the modem and the wireless router as well and give it another try. If the green light does not blink, then there might be a harware issue with your PS3. Good luck
Jun 04, 2011 | Sony Playstation 3 (PS3) Console
2 LIGHTS ON CONSTANTLY WON'T LOAD GAMES
make sure there is no disc inside first as stupid as it sounds people do do it, when you go to turn the ps3 on hold down the eject button b4 you press the power one then turn the power on whilst stil holding the eject button, if this does nothing when you turn the ps3 off hold down the power button this should reset its settings which can be the cause of no display on your tv
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on
hi Juan,
this is all i could find on the internet on what it might be.
Power supply is probably fried, but just try holding your finger down on the eject button and then flip the power switch back to on postion, it might help because this holding sequence re-boots the system and fixes some things.
or you could try this link to a youtube video,but what ever you try its at your own risk.
What to do when your ps3 won turn on
or see if this one helps you out.
Ps3 wont turn on Google Search
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
No picture any more
if your tv has a light blub replace it this is only for hdtvs
May 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
