Question about Acer TravelMate 225X Notebook
Swich is anybody knows how should I fix the 8s swiches from the motherboard, behind the HDD? is about a travelmate 225X thank you
    Scholar:
  • 94 Answers
Clarify
Posted on May 18, 2007
SOURCE:
How to swich on my HTC WINDOWS PHONE 8S ?
Are you 100% sure that its fully charged? Maybe a faulty battery or terminal. Batteries do fail after a time. Does it boot while plugged in?
Oct 06, 2016 | HTC Windows Phone 8S
Where do i put the hdd pwr, led pwr and the power swich on the motherboard
you have to consult the motherboards manual and look under "wiring-diagrams", if its a used motherboard there should be a product number on the motherboard itself and you could search on the net through another computer for the pdf.manual or "tech-specs" of that paticular motherboard, the manufacturers website should have all that info
Oct 10, 2009 | E-Machines W4885 PC Desktop
Forgot HDD password? please help?
Boot the computer in safe mode. You will be able to go in and reset your password. and once you are running you can always install your normal password. Depending on the operationg system usually F10 or F2 or on some the DEL key will get you into the safe mode.. Good Luck easy do once you are in safe mode....
Mar 23, 2009 | Acer TravelMate 2480 Notebook
Replacing HDD Acer Travelmate 244
First, you must remove the battery by pushing the battery release latch and sliding the battery out from the machine.
The hard drive will be located behind where the battery was, and you should be able to just carefully slide it out. Then you have to remove the hard drive from its holder by removing 2 screws.
Go to pages 52 and 55 on this document for complete instructions.
http://209.85.173.132/search?q=cache:Bd_vXG3IRTMJ:www.acerpanam.com/synapse/data/7117/documents/tm240_250sg.pdf+how+to+replace+hard+drive+in+travelmate+240&cd=16&hl=en&ct=clnk&gl=us
Mar 14, 2009 | Acer TravelMate 240 Notebook
Acer travelmate 225x
Hi!
You may buy a recovery cd for your laptop on this site:
http://www.user-guides.co.uk/cddownload/Acer/AcerTravelMate/Acer-TravelMate-225X-Data-Recovery-Boot-Disk-CD-98-XP-57411.html
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 31, 2008 | Acer TravelMate 225X Notebook
Acer travelmate 2300 motherboard problem
Sounds to me u hav not done proper Soldered it onto the motherboard. CHECK THE WIRING AGAIN.
Jul 27, 2008 | Acer Computers & Internet
Wiring diagram
the make of board is MSI model number MS 7094 ver 1.4. What I need is the colour codeing of the wires especialy the ones pow led +- which way they go as they are seperate hdd which is black and white, power sw orange and white, reset sw blue and white I have a yellow plug which says hdd audio I do know that some of these wires go into JFP1 and JFP2 but not sure which way they go as the + and -
Thanks Lipreader
Jul 10, 2008 | Intel Motherboard
Problems detecting the HDD in my travelmate 331t
ribbon connection From Motherboard, Not supplying power or not enough power.
Try An external USB Hard-Drive, see if this Works.
Check Connecting pins On hard-Drive And Computer Mating Surface. Blow to remove Any Dust.
Make sure it,s Connected Firmly.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 331T Notebook
CMOS battery bad
Acer TravelMate 225X solution:
The battery type CR2032 (Lithium, 3V, 20mm/3.2mm) is the same as mentioned in solution #1 but you must use a cell with connected wires and a 3-pin connector. It is hard to buy. A workaround is (1) to use the battery with connected tabs or (2) the battery holder (maybe BH1060 or similar). Original wire and connector from old battery must be cut out and soldered to new battery tabs or holder pins. Remember polarity - note the wire colors.
The battery position is under keyboard in the central position between the PCMCIA slot and the CD-ROM slot. Remove the strip cover near the display, slide the keyboard in the direction of display and lift it up.
Oct 09, 2007 | Computers & Internet
Acer TravelMate 225X Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
