Question about Whirlpool Duet GHW9150P Front Load Washer
Washer my washer is very loud all of a sudden on the spin cycle
  • sn1960 Nov 05, 2008
    can we replace the bearings our self or does it have to be a repair man?
    President:
  • Whirlpool Master
  • 2,651 Answers
Ouch generally a bad rear bearing..sound god awfull almost hurting your ears to listen too??? a rear bearin replacement requires inner tub, outer rear tub, new pulley. quite expensive repair, if not covered under a warr. luckily multiple yr warr on part offered by manufactue, id cvall so see what if anything would be covered
Posted on Nov 05, 2008
  • Ron Coons
    Ron Coons Nov 05, 2008
    ummm, its real involved of a repair, everything gets disasssembled, as a serviceman thatsdoes this job, id have to say i would not reccommend homeowner try it, and if parts not covered youre looking at about 450 just for parts +shiooing, and if parts covered whirlpool would pnly provide for auth. servicer to put in
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
Washer stopped spinning suddenly
The fix was simple really. I went to Home Depot and bought a new Maytag washer. I am a genius.
Feb 28, 2009 | Kenmore Washing Machines
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Maytag MAV7600 - loud noise on spin cycle
It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Dec 26, 2007 | Maytag MAV7600 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
