Question about Whirlpool Washing Machines
The clean pump light comes on after a wash cycle or spin cycle
The Air Chamber for the Pressure Switch was blocked with liquid detergent and grease.
When I examined the machine I could see that the underside of the drum, plumbing and door seal was contaminated with mould, liquid detergent and grease.
This problem is thought to be caused by using a low temperature wash and a liquid detergent without bleach. This problem can be prevented by cleaning the washing machine once a month with 50grms of Soda crystals or one cup of distilled white Vinegar using the hottest wash cycle. Do not put clothes into the machine during this wash.
Posted on Nov 16, 2008
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
The water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Dec 07, 2009 | Hotpoint WMA54 Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Cleaned out pump & still no fix....
YES !! Make sure your door lock light comes on when you are entering spin cycle.If it fails to come on your CONTROL BOARD is BAD, sorry!!
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
No Spin Cycle
Your machine won't go into spin cycle most probably because it awaits for pump to start extracting water out of the basket. If the "Door Locked" light is on th an it means that either filter, pump or drain hose are clogged (unless pump burned). Turn off machine, unplug the machine, clean the filter, check for foreign objects inside filter and pump housing and finally check/unclog the drain hose.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
