Question about RCA P61960 61" Rear Projection Television
DEAD TV My big screen wont power up i have checked the fuse and is is OK.it has been work fine i have never had any problems with the set.can you give me some advice on what to check? Thanks Loco
    Sergeant:
  • 337 Answers
Is good you have checked the main fuse and is good,what that means is you have voltage going in but you loose it down the line,if you have no indication of power(no lights ,no clicks) you need to check if you have the 5 volts that power the microprocessor witch is the brain and it uses 5 volts to aperate,the 5 volts come from a 12 volt regulator so you will have 12 volts in one side and 5 volts in the other,if you have lights or clicks when you push the power button you have 5 volts but one of the other voltages is missing,Check the horizontal output transistor for a short,if it is bad it likely cooked the safety resistor that gives him the voltage.If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.Let us know if you need more information or how it went.
Posted on Oct 06, 2006
Turned off my tv yesterday and now it is dead!WHat happened?It was working fine and w have never had any issues like this
First things to do:
Make sure where its plugged in for power is good.
Check power cord is ok
Look inside the set for the main fuse (follow power cord into the set if able)
if not able to do these have a tech or shop look at it.
Dec 23, 2012 | Sanyo DP50747 50 in. Plasma TV
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Tv dead power through on/off switch
yes there is a fuse.that is located on the main board.and that fuse is mostly blown and needs to be replaced. you can get new fuse at  www.radioshack.com at the rate of $2.
May 05, 2009 | Televison & Video
Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Feb 08, 2009 | Philips 47PFL7422D/37 Television
Rca big screen, no power light,, dead!
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf 35v.ck second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
No power
Hi there!
Where you saw the Arcing, check closer to see wether the components are not loose on the board. You may only have to resolder the joints and problem solved. If the arcing takes place towards the tube, then you have a more serious fault. Thus involving High Tension, so I would not advise trying to repair that area if you are not familiar with TV repairs. Please unplug set before commencing any work. Regards and good luck, JUS004
Mar 31, 2008 | Sony KV-32S26 32" TV
LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Nov 28, 2007 | Televison & Video
32v434t dead
please go according to procedure 1 isolate h/output section supply. 2 check power supply output is ok if not repaire it. 3 after power supply is ok 4 check hor osc, driver &output if problem repair it. 5 check for loose contact or print break. 6 connect supply to hor section. set will work fine. good luck.
Sep 21, 2007 | RCA 32V550T 32" TV
TV does not turn on
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine. Anyone have any wisdom or experience on these sets they can interject? Thanks!
Sep 05, 2006 | Panasonic CT-32SX12 32" TV
RCA P61960 61" Rear Projection Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
