Question about IBM ThinkPad T42 Notebook
Ibm T42 problem with usb ports and PCMCIA bay
When connecting any usb accesorie my pc just displays a blue screen with text that is not possible to read because disappeare very fast and doesn't start until I disconect the usb.
If I start my pc with no usb it works as great, but sadly I need to use usb port.
Please any help woule be very appreciated.
Best regards
Al
  • 3 more comments
  • Anonymous Dec 05, 2008
    i have the same problem too.
  • Elevenchains Dec 14, 2008
    My Ibm Thinkpad has winxp installed.
    I haven't found a solution, so any help would be great!!!!
  • jBond4321 Jan 04, 2009
    My T42 just wont even see what has been plugged in. I have done some searching and loads of people are have the same issue, which dont help me. My machine is just outside its extended 3 year warranty.
  • Anonymous May 15, 2009
    tengo una T42 y al conectar dispositivos como smart phone o ipod no los recnoce, ya segui los pasos que da la el equipo por defaault y se soluciona
  • Scott Hill
    Scott Hill May 11, 2010
    operating system please
Hi i just reinstalled window xp3 for my t42 ibm laptop, the modem hardware need a driver , so i downloaded a driver from internet ibm and downloaded to ibm 42 but it still could not recognized the modem? what whoul do? please
it worked a few days ago.
i tried all drivers / but still no help
KLYPHAN@aol.com
Posted on Sep 03, 2011
  • 558 Answers
First let me say i take a rather blunt approach to o/s issues, this being said I think re installation of the O/s xp sp3 and then update of the drivers fro the laptop from IBM web site would be the best way to go with this. I feel that most likely the drivers for the ports you are using are not up to date for your devices (usb items).
I appologise if this is not what you wanted to hear but it is the best way to get working thos areas that are malfunctioning at this point.
Last if this does not solve the issue then the Motherboard would be the next item I would investigate as causeing problems a replacement would be called for if it is suspect as damaged or defective.
Posted on Dec 15, 2008
Does the ibm thinkpad t42 have a sd port?
No, it does not. you can add an USB one.
Dec 14, 2010 | IBM ThinkPad T42 Notebook
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
I have a 4 yrs old IBM Thinkpad (Model R51) and its USB port is not working. There are some lines on the screen as well. What is the cheaper way to get it sorted out. Somebody told me motherboard has to be...
There are several PCMCIA USB ports available, I have an IBM T20 and I bought a Belkin USB 2.0 card from ebay for under $20, it has 2 USB ports, (and I've seen them with up to 4) and most electronics store should have them. They also come with Firewire ports if you choose to go that route
Sep 24, 2009 | IBM ThinkPad R51 Notebook
On screen display of volumn keys on IBM T42
check it on the IBM site for the programme
Sep 03, 2009 | IBM ThinkPad T42 Notebook
Need WiFi instead of Bluetooth
You have two choices for a wireless connection, a PCMCIA card or a USB device.
My choice would be a PCMCIA card, because it frees up a USB port.
There are quite a few PCMCIA card to choose from, I favour Netgear and D-Link.
Their instructions make them easy to install and setup.
Let me know if you have problems.
May 14, 2009 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad 560X 2640 (PCMCIA WiFi Card)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 07, 2009 | IBM ThinkPad 560 E Notebook
Thinkpad 380ed + USB PCMCIA-card. Can it work?
This is probably due to the power requirements of the pcmcia card you have plugged in. There are 5volt and 3.3volt slots. You have probably plugged a 5volt card into a 3.3volt pcmcia slot.
Apr 13, 2008 | IBM ThinkPad 380ED
VGA port problem
That could be a video card driver issue. It seems that when the projector is connected, windows detects it a create another screen using up more memory. Try download a latest video card driver for your laptop http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1rd635ww.exe this is for Windows 200/XP for the IBM Thinkpad T42. If that doesn't work then you should also try updating your operating system. Hope that helps!
Sep 11, 2006 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
723 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
