Question about Intel Motherboard
Gigabyte GA - x48 - DS4.
I got a Gigabyte GA x48 ds4, and a Sapphire radeon 4870 as  graphic's card.
When i start somthing that drains any GPU at all(3dmark, VLC movie files and games forexample), the graphic card goes into hyperdrive. I'v tried all the bios verision's with every graphic card verison of driver.
But, i tried another graphic card (Nvidia Geforce 8800GTS) which worked almost perfectly. So is this a hardware problem, a software problem or what causes it? I got 2 Sapphire radeon's, i ran em in Crossfire at first but one of em went into hyperdrive and i just took it out, and then the second followed after.
(I have also tried the newest Beta driver for the motherboard)
Mads Fercho Nesvold =)
(midax1@hotmail.com)
  • Plineh Nov 06, 2008
    Well, i tried this. Even put CPU/PCIEX Clock Driving Control CPU/PCIEX Clock Driving Control down to 700, well. same problem...
    Just after installing the driver for the Sapphire Card, BAM *broooom broom*
    So, any other ideas?
    Thanks for trying tho :)
  • Anonymous Mar 15, 2014
    manual GigaByte GA-X48-DS4 rev1.3
    President:
  • 2,351 Answers
Hi Plineh,
It sounds like a bios issue. (So it would be considered a hardware issue).
Uninstall all driver software for the radeon. (If the software for the nVidia software is in the system, uninstall it as well). Check your bios settings, see page 51 in your manual.
Set, Robust Graphics Booster, to [Auto].
CPU/PCIEX Clock Driving Control [800mV] you may need to go lower.
CPU Clock Skew Control [Normal]
(G)MCH Clock Skew Control [Normal]
System Voltage Control [Auto]
DDR2 OverVoltage Control [Normal]
PCI-E OverVoltage Control [Normal]
FSB OverVoltage Control [Normal]
(G)MCH OverVoltage Control [Normal]
Loadline Calibration [Auto]
CPU Voltage Control [Normal]
(Restart the system with one radeon installed into PCIE_16_1 slot.) Once windows finishes loading re-install the latest software for the radeon. (Download from here):
http://www.sapphiretech.com/us/support/drivers.php
Monitor the card & see if it goes into hyperdrive. If it does not than sut down the system & add the second card into PCIE_16_2 & run in crossfire mode.
You may need to adjust the bios setting further if either card goes into hyperdrive. Your board was made in 2008 & is still under warranty. I call to the manufacture's tech support is something I would not exclude.
http://www.gigabyte.com.tw/Company/ContactUs.aspx?CompanyWebPageID=6
Good luck & take your time!
Mike
Posted on Nov 05, 2008
  • Mike Peluso
    Mike Peluso Nov 06, 2008
    Its possible there are more settings in the bios that I am missing. Try calling Gigabyte! Your manual should provide a number or try the link above. If it was my board I would call.
    I found nothing through Gigabyte's FAQ's. (This is one for tech support). Don't was your warranty, use it!
    Mike
Distortion on display picture
Try installing the latest video card drivers for the GPU.
http://support.amd.com/en-us/download
Step 1: Desktop graphics
Step 2: ATI Radoen 7xxx (Legacy)
Step 3: Radeon 7000 Series
Step 4: select your current version of windows
Click "Display Results"
Sep 06, 2013 | Sapphire RADEON 7000, (64 MB) PCI Graphic...
Loaded card but black screen
There are several reasons :
your motherboard is dead
your monitor is dead
you didnt connected psu tu gpu if gpu needs it
Jan 26, 2013 | Sapphire RADEON HD 3450 AGP Video Card
Motherboard not starting
Hello try downloading the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2810#dl
Many things can go wrong, when the mainboard does not start.
Here is a check guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Most common problems is the power supply, the ram, wrong connected front panel, and bad capasitors on the mainboard.
Any beep codes ??
Post back a comment.
Good luck
Jan 09, 2013 | Gigabyte Motherboard Socket775...
I have a Gigabyte GA-81945GZME-RH motherboard that needs a new graphics card was wondering will ATI Radeon 5570 1GB PCI-E graphics card work. Thanks for any help you can give me.
The motherboard has a PCI-E slot, so the Radeon card will fit. You might need to upgrade your power supply, as a 400-watt supply is recommended on AMD's site for this card. Otherwise you shouldn't have any problems with the new card.
Jan 17, 2011 | Gigabyte GA-8I945GZME-RH Motherboard
Want to konw that will new graphic cards work on my pc??
I suggest that you need to buy the SAPPHIRE Radeon HD 5770 1GB graphics card. It is compatible to your ASUS motherboard. It will display and work faster.
Dec 23, 2009 | Computers & Internet
Ga X48-ds4 Lga775 DDR2 1600 MHz FSB (Front Side Bus) support DDR2 1200 memory with Intel ECC technology featuring faster speeds and higher data bandwidth can i use ECC uobuffered Memoty tmark@inbox.com
You can use that model of ram, though, it will definitely perform extremely horrible, as I'm using ECC unbuffered below 3200, it runs... But poorly.
Aug 13, 2009 | Gigabyte Computers & Internet
Expand graphic card
Hi!
First of all i want to sugest you to make sure that you have maximum of memory, you gona need it if you want to edit videos.
If you want to do video editing the most inportant component is the CPU, then comes the memory, after the memory come the HDD, and after that the GPU
Now the GPU, you have a pci-e 16x port on that MB, so i will give you 3 diffirent sugestions, from a not that expensive to a more expensive to the third that is expensive but not the most expensive GPU there is, all of the very goos for vidoe editing.
1) SAPPHIRE RADEON HD4670 512MB GDDR3 PCI-E VGA/DVI/HDMI
2) SAPPHIRE RADEON HD4870 512MB GDDR5 PCI-E DVI
3) ASUS RADEON HD4870 DARK KNIGHT COOLER 1GB PCI-E DVI
There u have 3 very good GPU:s, but as i told you the most important is the CPU and the memory!
Good luck
Nic
Apr 02, 2009 | ASUS P5RD2-VM Motherboard
GA-K8VM800M and GV-N76G256D-RH compatibility
Perhaps your power supply is not powerful enough for the new card.
Mar 01, 2008 | Gigabyte GA-K8VM800M Motherboard
I won two ati sapphire x1950pro graphics cards but don`t know if my system can deal with them.
Man Great win you have some kick-A$$ cards but I am sorry to say your current MB does not support crossfire video cards. But if this a store bought system from Packard Bell you should have a Name: ATI Radeon X300 (RV370 SE) that your computer came with. Just to tell you one of these bad boys will put the Name: ATI Radeon X300 (RV370 SE) to shame if this is what you have in your system.
Nov 20, 2007 | Computers & Internet
Intel Motherboard Logo
263 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
